You would have to add gallons per tank before you got close to adding too much. A 7.3 would probably run on the stuff - it runs on just about anything. The damage you are doing by adding more than the recommended amount is to your wallet.
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
