Dually Fender Lights Popping Out - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 07-09-2008, 05:59 PM   #1 (permalink)
Huminie's Avatar
Question Dually Fender Lights Popping Out
Hi Folks,
I am having a bit of a nuisance issue with my truck. About a month ago, one of the fender lights 'popped out' causing it to dangle on the side of the fender. As luck would have it, I had a routine service appointment already scheduled a few days later, so the dealer took care of the problem for me. It was a simple fix...a slide clip fell out of place but the wheel well had to be removed to get to it. The mechanic said this happens when the back end bounces around...well, duh, isn't that what the back end of pick-up trucks are sposed to do?
I just got back from a 2,000 mile road trip where the truck pulled my 38' fifth wheel up and down mountains flawlessly, but I now have 3 of the 4 lights popped out.
I am going to have the dealer take care of this again for me, but I am wondering if anyone else is having this issue and if there are any other suggested fixes to it doesn't just happen again and again.
Thanks in advance for any constructive advice you may have!
-Adam
2008 F-350 Super Duty FX4 DRW 6.4L Turbo Diesel
2005 Toyota 4Runner Sport 4.7L V8 4WD
Huminie is offline
Old 07-09-2008, 08:53 PM   #2 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
I had this happen to me.
Loose side marker lamps, 2008 dual rear wheel pickups:
Some trucks may have marker lamps that are loose on the fenders, or fall out. If the side marker lamp assembly must be replaced, discard the bulb that comes with the assembly and install bulb p/n C2AZ-13466-C. The lamp retaining bracket, F81Z-15A436-AA, should be replaced as well. Red marker lamp: F81Z-15442-BA; amber marker lamp: F81Z-15442-CA. Broadcast Message 0352.
Shawn
2008 F-450 JOB-1, 4 X 4 with 4.30's, auto with manual transfer case with factory cup holders. All options except sunroof and nav. Line X with Extra. 24K Draw-Tite Signature Series Fifth Wheel Hitch. 65 Gallon KSH Marine fuel/tool combo in bed. Viair 480C compressor with 8 gallon tank. Hadley Air Horns hooked up to Auto Mate alarm. Chime/Light Killer Mod. Polished Job-1 exhaust tips. Transmission upgraded to JOB-2 filter, pan, and lines. External filter eliminated.
PICTURES
GEARJAMMER is offline
Old 07-09-2008, 10:04 PM   #3 (permalink)
Huminie's Avatar
Ahhhh...so this is a known issue then! Thanks for the info...I will make sure the dealer fixes this 'right' this time around!
-Adam
Huminie is offline
Old 07-09-2008, 10:14 PM   #4 (permalink)
Huminie's Avatar
BTW...can you tell me where to find this info online?
-Adam
Huminie is offline
Old 07-10-2008, 12:25 PM   #5 (permalink)
Huminie's Avatar
Nevermind...I found it here:
6.4 PowerStroke bulletins
-Adam
Huminie is offline
Old 07-10-2008, 06:57 PM   #6 (permalink)
Thanks for the info. I too have had the issue with the lights popping out. I have also had issue with the fenders rubbing the paint and showing a scrstch line down the sidre of the truck.
first_ford is offline
Old 07-15-2008, 05:55 PM   #7 (permalink)
ddduallyfan's Avatar
Thats quality.
ddduallyfan is offline
Old 11-09-2009, 10:40 AM   #8 (permalink)
burnetma's Avatar
This just happened to my truck. Two of four lights popped out. Has it happened to you since?
Has anybody done this repair themselves?
2008 F350 FX4 Crew, 4x4, 6.4L, Torqueshift, 4.30, tow command, leather, power everything. 75k+ miles. Built 4/17/2007 (Job 1), Purchased used 3/16/2009
2010 Mustang GT Premium - 4.6L-3V, 5 Speed, Grabber Blue - Now this is FUN!
1997 F250 EXT Cab, 4x4, E4OD, 4.10, 273k+ miles.
Modifications: Pyro & boost guage, 202 T-stat, transmission cooler & Tymar - SOLD!!!!!!!
2004 John Deere 5420 MFWD Utility Tractor with 541 MSL Loader.
burnetma is offline
Old 11-09-2009, 11:37 AM   #9 (permalink)
i started replacing them on my truck and my friends trucks with 2" round 9 led lights. and i will never look back. if i was to buy a brand new dually the first thing i would do it change them over. if its good for a tractor trailers that are on the road every day all day then they cant be half bad. i have never had good luck with the stock setup even tried after market ones they get water in them the plugs get all buggered up.
2001 F350 SuperCrew Long Bed Dually.
7.3L turbo Diesel, automatic transmission, goose neck hitch, fifth wheel hitch, stainless steel back rack, 315/75-16 BFG A/T's, AUX back up lights, euro-lite driving lights, upgraded fog lights, dp-tuner, turbo master wastegate controler, dieselsite boost relief valve brv+, auto-meter ultra-lites, 5in stacks no muffler, whelen towmans light bar, DIY tymar intake, DIY coolant filter, 2M ham rig, DIY AIC,
( egauges )
My truck pic's
cdacaraudio is offline
Old 11-10-2009, 02:47 PM   #10 (permalink)
burnetma's Avatar
Just so I understand, when you changed to the 2" round LED type, do you need to modify (cut) the fender?
burnetma is offline
Old 11-16-2009, 11:33 AM   #11 (permalink)
i had to open the hole just a little i can get some pics if you would like. i have put around 12k miles on the truck sense i put these on and have not had any trouble.
( egauges )
My truck pic's
Old 11-16-2009, 12:52 PM   #12 (permalink)
Pics would be great, I've been plagued with the problem since day one.
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
2007 Keystone Raptor 3712TS PICTURES
newbie_101 is offline
