Hood prop rod - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 06-28-2009, 09:55 PM   #1 (permalink)
Hood prop rod
I have had the hood prop rods changed twice now because they keep popping off. They have been under warrenty until now, over the miles. Is this common, and if someone has been successful at fixing this I would appriciate the info
1997 Crew Cab, Gear Venders, Transfer Flow, Garmin 2720 GPS
1997 F250 Supercab Transfer Flow tank
2008 F250 Crew
dbmaxwell is offline
Old 06-28-2009, 10:12 PM   #2 (permalink)
compman72's Avatar
My Photos: (9)
If they are just changing the gas cartridges maybe they need to change the mounting studs too. ??
Never had this problem though.
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
compman72 is offline
