'08-Up General QuestionsGeneral questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
I have removed the panel under the steering wheel and found the bundled wires, including those from the upfitters. Careful that stamped steel has some sharp edges. I want to hook up the elevated idle circuit. My question is, which upfitter switch would you recommend for this? I think the lowest amp rated switch should do the trick, saving the higher amperage switches for the big back up lights I want to install. Also reading the Ford brochure on SEIC, it states that the torque converter will be latched up, allowing for PTO operation. I don't need nor want the torque converter to latch up, rather only wanting elevated idle for faster warm ups on cold days or if necessary prolonged idle with the cooling down of the engine.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC http://community.webshots.com/user/C...host=community
2004 F-350 Lariat 4x4/CC/SRW/6.0 PSD
18 Inch Suspention with Atlas Springs,Cross Over Sterring, 6 Chrome 2.5 Kings Piggy Backs, Ladder Bars Front And Rear With Heims,Custom Cross member,Re-Indexing Ring On Transfer Case,4.56 Precision Gears, Lockers Front and Rear, High Angle Driveline Long Slip Front Shaft, High Angle Driveline Two Piece CV Rear Shaft,Sdhq Steel Braided Brake Lines, AMP Research Steps, On Board Air, RBP Turbo Back Exhaust With 6 In Tip,AFE XP Intake,Banks Intercooler,03 Turbo,Heads Ported & Polished By John Wood,ARP Headstuds,SCT By John Wood,Zex Nitrious System,3 Gauge Pilliar (Boost,Pyro,Trans),Mag-Hytec Front & rear Diff Cover, Mag-Hytec Trans Pan, Eclipse 3423 In Dash Dvd,3 JL Audio 10s Behined Seats, And 2008 Front Clip With An RBP Grille
2008 F-450 Lariat 4x4/CC/DRW/6.4 PSD 4.88 LS
Donahoe Racing 2.5 Leveling Kit, Still Working On The Lift For The Rear, Pulls 2006 Weekend Warrior Cl 4005
2005 F-350 Lariat 4x4/CC/Drw/6.0 psd/4.10 Rears
Sold
