How do i remove the inner door panel on and 08 F250? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 10-23-2009, 06:20 PM   #1 (permalink)
fatfender48's Avatar
Send a message via MSN to fatfender48
have to replace my passenger side mirror part of the plastic got broken by a stone
when the new one arrived i looked and there are 4 bolts all i could see when i removed the platic was 3 till i looked closer the forth one is buried and i will need to remove the door panel
anyone know how to do this?
2003 Superduty 7.3 AFE Stage 2 Cold Air intake with cover, Autometer Guages, ZooDad Mod and Cover, Hyperteck power programmer
fatfender48 is offline
Old 10-25-2009, 09:06 AM   #2 (permalink)
Fanuc's Avatar
There are two screws at the bottom of the panel ... unscrew them ... then right below the arm rest there a small panel about 3"x1" pop that off and remove the two screws there ... the panel then lifts stright up and off
Fanuc is offline
