I have a "Clunk" - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 11-17-2009, 08:10 PM   #1 (permalink)
StanMI's Avatar
I have a "Clunk"
Truck is going in tomorrow (if I can get some time off).
I'd like to know if anyone here has any ideas what i might have.
Intermittent clunk sound coming from what seems to be passenger side and low in the engine compartment area. I have heard it stopped, under acceleration and braking. Sometimes I can feel it in my feet and sometimes I can't. I can't seem to do anything to cause it or I would say, "when I do this it does............" Any ideas.
I though maybe I had something loose on the outside but that doesn't explain why I can get it stopped.
2008 F350 Lariat CC Black two tone and darn near everything else.
StanMI is offline
Old 11-17-2009, 08:26 PM   #2 (permalink)
senix's Avatar
I had a clunk in my 06. Could never figure it out. Mine only happen first thing in the morning, and would happen just after putting it in gear.
Was there till I traded it in for my current truck.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is offline
Old 11-17-2009, 09:18 PM   #3 (permalink)
Matt0987's Avatar
Try the track bar bolts at each end. On my 03 Ex the torque is 450 foot pounds. But I did have a clunk until I replaced the bolt and nut on the passenger side.
I also had to tighten the one on the drivers side to reduce some play in the steering. It was as though the steering box was sloppy.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 11-18-2009, 09:08 PM   #4 (permalink)
Try turning the heat off and see if the noise goes away. I have a similar noise and others have posted that the noise is an actuator in the heating air duct system. in my truck the noise does go away when i tunr the heat off. There does not seem to be a known fix for this. Let us know what you find out from the dealer.
shaston is offline
Old 11-18-2009, 09:37 PM   #5 (permalink)
StanMI's Avatar
I'll try that.
So far the dealer can't find it either.
StanMI is offline
Old 11-19-2009, 09:25 PM   #6 (permalink)
StanMI's Avatar
I picked it up this afternoon and so far I am "Clunk" free. They went through the suspension, checked and retorqued everything. I put about 30 miles on it and so far no clunk. Hope that takes care of it. The work order also shows the TSB for the heater noise shaston noted as supposed to have ended with the 07 model year.
StanMI is offline
