Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up General Questions
'08-Up General Questions General questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 05-13-2008, 11:33 PM   #1 (permalink)
Integrated brake controller
Looking for someone who knows the in's and out's of the integrated brake controller on the '08 SD. My dealer and the owners manual state that this controller is only compatible with trailers having electric drum brakes. I am looking at buying a larger 5er but it has the hydraulic disc brakes. I haven't inquired, but I would think that these brakes would be in some manner electrically controlled as well. Has anyone dealt with this yet? Thanks.
Beserko is offline
Old 05-14-2008, 10:19 AM   #2 (permalink)
You might have better luck in the towing and hauling forum with this question, some have had problems some have not. The Integrated brake controller has been around for a couple of years. Good luck
08 F350 FX4 cc sb 6.4L BFG 305/65-18 Harpooned 12MPG MT
Ordered on 2/21 Born on 3/19 Mine on 3/30
SOLD 99.5 F250 sc lb 3.73ls 4x4 100k
08 Ecape Manual XLS 29MPG
28' Jayco Talon ZX toy hauler 10,000# w/o toy's tounge wt 1600# w/o toys or water
22' Renagade 3place snowmobile trailer 2000# w/o toy,s
98 FLHT
wolfe14785 is offline
Old 05-14-2008, 01:58 PM   #3 (permalink)
Stymie's Avatar
you have to install an aftermarket controller for hydro brakes
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains
Stymie is offline
Old 05-14-2008, 03:36 PM   #4 (permalink)
Ninebell's Avatar
I had Hydraulic brakes on my last trailer with the 08 F-450,they don't work you'll get disconnect messages all the time. And some times the controller did not even light up with the trailer hooked up.I now own a trailer with electric brakes and all works great.As stated above you'll have to install a after market controller for you hydraulic brakes for them to work correctly.
2000 F-250 7.3 PSD Extended Cab XLT 4X4 SB traded
2002 F-250 7.3 PSD Crew Cab Lariat 4X4 SB traded
2005 F-250 6.0 PSD Crew Cab Lariat 4X4 SB traded
2008 F-450 6.4 PSD Crew Cab Lariat 4X4 LB
Towed Vehicle 2007 Jayco Designer 34 RLQS
Ninebell is offline
Old 05-14-2008, 04:06 PM   #5 (permalink)
Dieselgem's Avatar
My Photos: (14)
It is a pc of junk for a big trailer. I added a P3 and the trailer stops on a dime. Great investment. PM me if you have any questions.
2008 F450- Truck Pictures
2008-41'CKS KZ Escalade Toyhauler
Toy Hauler Pictures
Dieselgem is offline
Old 05-14-2008, 10:03 PM   #6 (permalink)
It all depends on the hydraulic actuature on the trailer...
The trailers hydraulic brake actuator is what dictates the incab controller requirements. Ford's factory controller has been out long enough that some/many brake equipment is now compatible.
We run almost all hydraulic disk brakes on our fleet of trailers. We converted a dozen older trailers (mostly 8K axles, some 7K axles, goosenecks and bumper pull....all equipment trailers). We have required all new trailers the last several years to be hydraulic disk. We have found the Dexter actuator (http://dexteraxle.com/electro_hydraulic_actuators) to be one that works with most all in cab brake controllers including the Factory Ford control. We specify this actuator on new trailers we bid out.
I had a 2007 F250 with the factoy brake control, and now a 2008 F350. Both work fine with all our trailers.
BTW....once you have pulled a trailer with hydraulic disks, you will never go back to electric.
jjw
ND
JJW-ND is offline
