Keyless Entry LOCKED OUT HELP! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 12-08-2012, 11:01 PM   #1 (permalink)
NOSURF2DAY's Avatar
I forgot my code and punched in several codes trying to remember. The keypad started flashing. Did I shut down my truck? What happened by doing that?
Will the truck reset if I leave it alone? I think I remember the code not but when I typed it in the truck did nothing. Not sure if it is the wright code but I am curious if the truck security shut the truck down? Both sets of keys are in the truck.
Yeah I know I am a jack ass...
08 F250 SD; Edge Evolution Tuner; 10" FABTECH lift; 22" rims; 14.5x40 shoes
NOSURF2DAY is offline   Reply With Quote
Old 12-08-2012, 11:53 PM   #2 (permalink)
Iam4MSU's Avatar
If you bought the truck new or if you bought it from a Ford Dealer, I think you can go to them and get the keycode or get a new key cut to unlock the door. I have done this on a Chrysler product over the phone. You have to prove you own the truck which is why you go back to the dealer you purchased it from.
Get a slimjim and open the door.
2004 F250 Crew Cab King Ranch Lariat FX4 Saddle Leather 6.0 L FUMOTO Valve
AIRAID 4" straight No CAT No MUFF
Nitto Terra Grapplers All Terrain LT285/75R16 10 PR Everything else pretty much stock
NEW Ranchos installed 8/15/2010
WORK IN PROGRESS - R&R EGR COOLER, OIL COOLER, THERMOSTAT, TURBO BOLTS, GASKETS, ORINGS, and adding a COOLANT FILTER WITH NEW COOLANT AND FLUSH
Anyone Got Birds? Will Travel to Hunt!
We are all just Village Idiots,
Enamoured with our own shadow,
Oblivious to the setting sun!
Iam4MSU is offline   Reply With Quote
Old 12-09-2012, 07:43 AM   #3 (permalink)
Mark Kovalsky's Avatar
With proof of ownership you can go to ANY Ford dealer and cut a new key.
Mark
Mark Kovalsky is offline   Reply With Quote
Old 12-09-2012, 10:33 AM   #4 (permalink)
After you get into the truck by any means, this thread has the location of the key code. Bought Used Truck - Need door keycode
'08 F350 Lariat CC 6.4 DRW 4.10 4x4 manual hubs and 62 gal fuel tank.
rskeans is offline   Reply With Quote
Old 12-09-2012, 10:45 AM   #5 (permalink)
ford_doctor's Avatar
Dear Jack Ass,
The information you seek is in your Owner's Guide... This is part of the "Anti-Scan" feature and it is normal operation. It can be reset if it does not do so on it's own. Please read:
Originally Posted by 2008 F-Super Duty Owner's Guide
Anti-scan feature
If an incorrect code has been entered 7 times (35 consecutive button
presses), the keypad will go into an anti-scan mode. This mode disables
the keypad for one minute and the keypad lamp will flash during this time.
The anti-scan feature will turn off after:
  • one minute of keypad inactivity.
  • pressing the control on the remote entry transmitter.
  • the ignition is turned to the 3 (ON) position.
I highly recommend reading up on the keyless entry system in the Owner's Guide as there are instructions that will show you how you can program your own codes... perhaps one that you will easily remember. I did on all of my vehicles and used the same code too.
Good Luck!
Ford Master Diesel Technician
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline   Reply With Quote
Old 12-09-2012, 02:46 PM   #6 (permalink)
NOSURF2DAY's Avatar
I am up under my dash, i was able to get in the truck still cant remember the code amd am tryi g to find this elusive box so i can change the code.
i have the 08 anyone have a more specific spot where the box is that has the 5digit code on it?
scratch that after some more searching i found it next to the passenger side kick plate behind fuse box (DAMN IPHONE)
Old 12-09-2012, 03:32 PM   #7 (permalink)
scratch that after some more searhing i foind it next to the passengrr side kick plate behind fuse box
Correct. Excellent news.
Old 12-09-2012, 04:38 PM   #8 (permalink)
"Dear Jack Ass,"
Now, that is funny...
2009 F450 Lariat 4x4
2007 F350 KR DRW CC 4x4-Gone
2005 Mobile Suites 36TK3
wingnut60 is offline   Reply With Quote
Old 12-09-2012, 05:18 PM   #9 (permalink)
I programed mine to the universal password, according to the Penguins of Madagascar... 1-2-3-4-5 ;-)
Not really. As said any dealer can get you the code programed in by Ford (take your vin). Oh by the way, you aren't a jack ass. It happens. As the Disc Doctors use to say...it's a Franklin fix. Just going to cost you a couple bucks and now you know to write it down some place in your wallet or email it to yourself so it is on your phone. Make it your wife's birthday. That way you won't forget it and if you do, getting locked out of your truck is the least of you problems.
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, fumoto.
rock_doctor is offline   Reply With Quote
Old 12-10-2012, 12:14 AM   #10 (permalink)
NOSURF2DAY's Avatar
I did exactly this. I dont know how the hell I forgot the code. I was surfing all day so I figured I was just physically and mentally exhausted.
