keypad code on 08 F450 - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 01-04-2012, 09:19 AM Thread Starter
Jonbones's Avatar
trying to figure out the factory code on my 08 F450? I know they used to be on a module or something but not having any luck. Also once I find it how do I reprogram the Keypad?/ I have no owners manual tahts why im asking. Thank You!!
Jonbones is offline
post #2 of 12 (permalink) Old 01-04-2012, 09:33 AM
senix's Avatar
Go here and register by vin:
Official Ford Owner Site | Schedule Vehicle Maintenance, Get Tips, Advice & Coupons
there you can see all the owners manuals/supplements.
There is also a place where you can track and record maintance.
Code should be on the pcm.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #3 of 12 (permalink) Old 01-07-2012, 08:40 PM
The original code is on the back of the black box under the passanger kick panel. I was able to undo a few bolts and lean it out. There are several different numbers on there but keep trying them and eventually you will get the right one.
dlgthatsme is offline
post #4 of 12 (permalink) Old 01-08-2012, 05:23 AM Thread Starter
Jonbones's Avatar
I can see the fuse panel in there, pretty crowded but I don't see any bolts at all. Are you saying it's on the back of the fuse block itself?
Momma says the reason alligators are ornery is cause they got all dem teeth!!!
Jonbones is offline
post #5 of 12 (permalink) Old 01-08-2012, 08:34 AM
Link below might help. I never had to check for mine.
08 F-350 door pad code
- 2013
F350 CC 4X4 Lariat SRW, Black.
Ordered Dec 2012 - Built Jan 11th 2013 - Picked up Jan 31, 2013.
- 2013
Ford Edge
Built Nov 26 2013 - Picked up Dec 06 2012
-2008
F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29.
-1972
First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson).
-First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards.
-1982 - My Sister married a GM Sales Manager (He Retired, "Hello" Ford Super Duty, enough said, LOL).
-2003 - ZRX1200 (Some say "Mid Life", LOL).
-2008 - Jayco 313RKS 5th Wheel.
MPD56 is offline
post #6 of 12 (permalink) Old 01-08-2012, 06:43 PM Thread Starter
Jonbones's Avatar
Thanks but no help aftermarket radio and no owners manual with card, guess I'm stuck goin to dealer
Jonbones is offline
post #7 of 12 (permalink) Old 01-09-2012, 07:03 PM
Just pull the kick panel on the passanger side and lean the PCM out. Its on the back.
post #8 of 12 (permalink) Old 01-10-2012, 06:15 AM Thread Starter
Jonbones's Avatar
It won't move, there were 2 small bolts close to the "door"end but when I started to remove one all my lights started flashing got nervous and tighten it Ill just go see dealer
Jonbones is offline
post #9 of 12 (permalink) Old 01-11-2012, 05:20 PM
my dealer said they don't do that anymore on the newer models with the code on the back wall of the dash. They said the only way is to come in and they'll hook a laptop up to it and get the code. The dealer 2 blocks from me is always always a rip off for everything. They wanted $66 to get the code, I called another Ford they wanted $55, called another Ford they wanted $20, and finally called another Ford and they said bring it on down and they gave it to me for free. Think there is instructions how to reprogram it once you have it in the owners manual.
Biggredd2069 is offline
post #10 of 12 (permalink) Old 01-11-2012, 06:35 PM
deliberate's Avatar
I'd get to know that dealer, sounds lke a good one.
As far as "reprogram", IIRC you can add/change a "personal" code but you can not change the original factory code.
Should be a reminder someplace to folks considering a used truck to be sure that they are given the factory code as part of the sale.
Good luck,
- Don
2010
F350 SRW 6.4L 3.55 CrewCab FX4 SB KingRanch - built Jan 2010 - bought new Dec 2010
"You can set my truck on fire, roll it down the hill, and I still wouldn't trade it for a Coupe d'Ville."
Rant: Do you know what you actually pumped into your tank on last fill-up? (cetane level, fuel quality, water, etc)
Notice: Anything that I or anyone else writes about my vehicle on this, or any other, website pertaining to modifications or alterations, is only for discussion purposes and/or to gain acceptance from my peers, and may not actually represent anything existing on my truck, and thus, can not and should not be held against me in any issues, i.e. warranty claims, whatsoever that may arise for any cause.
deliberate is offline
post #11 of 12 (permalink) Old 01-11-2012, 07:49 PM Thread Starter
Jonbones's Avatar
Good advice I'll pass mine on when I sell it
, if I sell it !
Jonbones is offline
post #12 of 12 (permalink) Old 01-20-2012, 04:00 PM
I found Mine!! '08 F-350
Ok, I literally just found mine 5 minutes ago. I'll try to give detailed instructions for finding it. It IS on the computer module behind the passenger kickplate.
1. First remove the fuse panel. I removed the floor mat to make it easier.
2. Then remove the threshold (door sill). Its just held on with clips. It pops off really easy.
3. The passender kickplate is just held on by the weather stripping and the threshold, so once you remove the threshold and pry the weather stripping from on top of the lip of the kickplate, it will simply come away from the truck.
4. The computer module is the black box held on with a couple of screws in the body of the truck. You will have to remove the "wiring harness" that is connected to the box. Its a "white" plastic thing with a bunch of wires coming out of it. its just held on with 2 pegs. A Flathead will do the trick. this will make room for tools and such.
5. The screws holding the computer to the body have a 9/32 hex head, so keep that in mind when you are choosing tools.
6. Remove the two screws (one in front and top, the other is underneath). Once the screws are out the module will NOT come away from the body but simply be able to pull away a little bit. This is just enough to see the number.
7. Get your good flashlight, and look on the back of the module (facing away from the truck. There will be a sticker on the back with a big C on it. the sticker will be upside down. Look in the top right corner (lower left if the sticker was right side up). There will be a 5 digit number. THIS IS IT!!! CONGRATS!
I put this post up because I had hell trying to get this number, and like to help others. I hope I have. My dealer wanted $55. I refuse to pay that, especially since all it took was a little information, patience, and determination. Good Luck.
2008 F-350 SD Lariat Long Bed
ck919 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
