Limited Slip Question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 01-22-2008, 07:43 PM   #1 (permalink)
My truck is equipped with a limited slip rear diff. Unfortunatey it seems to have a lot more slip than I like. This causes me to have to use my 4wd just to get up a paved drive with a little snow cover. So my question is Can I do something to help it lock up better, giving it the berries only causes the traction control to engage which doesn't seem to do much but cut engine power to nothing. Perhaps there are others out there that have similar issues.
Michael
2008 F-250 4x4 Crew Cab Lariat 6.4
2003 F-250 4x4 Crew Cab Lariat (Sold)
domersconstr is offline
Old 01-22-2008, 09:07 PM   #2 (permalink)
Unfortunately a limited slip requires torque to push the side gears against the clutches and thus grab both wheels. In ice, snow, or wet grass it will be useless because of the low input torque required to spin the tire. They are effective on pavement and dry dirt. You can drain the oil and refill without or with less additive, but then you'll get more tire wear.
Early '99 PSD SRW 4X4 GTP 38R, DI intercooler, Stealth SRP1, DS regulated return, Stock injectors, Ford AIS intake, DP tuner, 203 t-stat, Gauges, coolant filter, Amsoil bypass.
ATS trans and converter, 31 row cooler, external filter, 4.10 ARB Lockers, Traction Bars, 33" Toyo MT, tons of other stuff.
2005 Harley front end, Trail Ready, Daja Design, Vision X
project20v is offline
Old 01-22-2008, 09:50 PM   #3 (permalink)
A trick I"ve learned to use when I'm in the mud or slippery grass, going forward, is to slip the transmission into 2nd gear instead of first. First in the automajic has so much torque that it won't take anything at all to slip the wheels, but I can get out of slippery spots relatively easy starting out in 2nd. At least it works for the 4r100 transmission. I would think it would work in the newer transmission too.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 01-22-2008, 11:04 PM   #4 (permalink)
nascarj's Avatar
My 02 had the standard LS rear and it also let a lot of slip. My 08 doesn't seem quite as bad. I think a locker or maybe a T2R like I have in my race car are the only rear solutions.
j
02 F250 XLT CC/SB/2WD 7.3 PSD- DP Tuner 6 Position Chip, MBRP 4 in exhaust, AFE Stage II, A-pillar ISS Pro Gauges- Died
08 F250 XLT CC/SB/2WD 6.4 PSD- Bone Stock... For now- Gone
11 F350 Lariat Dually/CC/LB/4WD 6.7 PSD
11 48ft CargoMate enclosed race trailer
04 Crossroads Cruiser 28BH 5er
Fox body Mustang GT- NASA American Iron-Central #76 AND
S197 (2005+) Mustang GT- NASA American Iron-Central #75
http://www.facebook.com/TeamUBR
http://www.drivenasacentral.com/
nascarj is offline
Old 01-23-2008, 07:43 AM   #5 (permalink)
Mark Kovalsky's Avatar
It will work on the newer trans. There's even a better way on the TorqShift - you can start that trans in 3 and it will start in 3rd gear.
Mark
Mark Kovalsky is offline
Old 01-23-2008, 10:37 AM   #6 (permalink)
Stymie's Avatar
another bit of help is to apply light brake pressure.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Similar Threads
Limited Slip Question itherrkr 1999-2007 Ordering Information 24 11-06-2006 08:56 PM
limited slip question ta152h0 6.0L Power Stroke Engine and Drivetrain 3 02-08-2006 06:04 PM
limited slip question aeomholt E-Series Vans 3 01-21-2006 11:37 AM
Limited Slip Question Land_Surveyor Power Strokes 1994-1997 Upgrades and Aftermarket 11 03-07-2005 09:26 PM
Limited Slip or Not Limited Slip - That is the question h2ojunkie Power Stroke Excursions 2 03-27-2004 07:40 AM
