Locking dif. Do you use it? Looking @ a couple 2008's - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 10-20-2009, 06:44 AM   #1 (permalink)
Looking to buy a used08 250 and one has the locking dif. Do you use it? My 7.3 never had it and did just fine. Pull a trailer all the time an sometimes drive on the beach, but never had it. When would you need it?
Most of the 08's I have been looking at don't have it but one does.
galeforce is offline
Old 10-20-2009, 07:50 AM   #2 (permalink)
davydee's Avatar
We don't, but I wouldn't hold the locking differential as a negative if you like the truck. My experience with locking diffs is that I spin two tires instead of one.
2009 F450 Pickup Lariat Plus w/Nav, 4X4 Off-Road Pkg, Rhino bed liner, 50 gal Transfer Flow fuel tank, 24k Reese Signature Series 5th-wheel hitch.
2011 MS 36RSSB3
davydee is offline
Old 10-20-2009, 10:00 AM   #3 (permalink)
NEVERSWEAT7's Avatar
I have locking diff on my 77 F-250. Front Dana cage with Detroits pressure sensitive activation...bulletproof too. With paddles on the monster the beach with lockers was awesome! But, I was highly hedged there. Loved it playing in the snow too so it was to my advantage to have lockers. The Rubicon also has them for rock crawling.
The common thread here is I used them more than the average driver would based on my environment. I risk a little more so I hedge myself a lot more.
Is it just a luxury or does the environment where you drive and live warrant it? If your in beach sand , as mentioned.. two wheels will spin, but in some cases it could provide just enough of that quick fix to get you on terra firma.
If the truck comes with it and you like it.. get it. It is a tool in the box you will have for that warranted event.
2010 F-450 King Ranch (loaded)
Alpenlite Portofino RL36
Reese 24K Sig Series fifthwheel hitch
Reese 30K Sig Series gooseneck hitch
Aerotank 65 gallon tool/tank box ( on timer)
Eclipse AVN726E Nav
NEVERSWEAT7 is offline
Old 10-20-2009, 12:54 PM   #4 (permalink)
lowerd96's Avatar
My Photos: (37)
Is it a front locker? Rear locker? Selectable or full time? I think if it's a full time rear locker you will get sick of it on the street. But that one time you are in the sand and it pushes you through you will love it. Driving on icy roads is another adventure with a full time locker, so think about that too...
Silver Metallic 2008 F-350 Lariat, Crew Cab, Long Bed, PSD, 4x4, Auto, MoonRoof, Medium Stone Leather, Heated Captains Chairs, Tow Command, Upfitters, Memory Group, Audiophile, Camper, Tow and Off-Road Package...Banks Monster Exhaust, 3.5" Icon Leveling Kit, 35x11.5 Toyo AT's...
lowerd96 is offline
Old 10-20-2009, 02:39 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
The optional diff is not a 'locker". It's a limited slip (LS), or what GM caalls a positraction. It works automatic. If one rear tire begins to slip, the torque is transferred to the other. The only time you notice it is if it doesn't work - usually because the driver doesn't know how to make it work.
When you have one rear wheel on slicky stuff such as snow or ice or even wet grass, the tire in the slick stuff will spin while the other doesn't do anything if you don't have LS. But with a properly-functioning LS, the torque gets transferred to the tire with traction and you move out. But you may have to gently apply the brakes and the go pedal at the same time to make the LS catch and do it's job. So maybe it's semi-automatic?
And no, Ford doesn't offer an LS option for the front axle. But the 2008 F-250 4x4 has a Dana 60 front axle with 9.75" ring gear and 35 splines, so LS units for that axle are available. For example:
DS 71598 - Dana 60 4.10 & DWN 35Spline TracLoc (F/F or Semi-float) COMPLETE POSI , incl ABS .
SmokeyWren is online now
Old 10-22-2009, 06:43 PM   #6 (permalink)
sbrennan007's Avatar
Great explanation here. I couldn't have stated it better myself.
2011 F250 SC Lariat 6.7L Tuxedo Black
2011 BMW X5 XDrive Turbo
sbrennan007 is offline
Old 10-23-2009, 06:37 PM   #7 (permalink)
Parts Jimmy's Avatar
The 2011 F250-350 SRW will have a optional electric locker (a real locker similar to a ARB) for the rear diff. That is a option I wish that was available when I bought my truck.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights
6.0-6.4 PSD Motorcraft Filter Comparison Video
Fuel Quality Video
Parts Jimmy is offline
