Lower Shock Bolt? Size? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 01-24-2008, 07:53 PM   #1 (permalink)
Hey guys.... anyone know off hand what size the lower shock mount (front) bolt is? Is it a 14mm bolt? I'm stuck at work with the truck all apart and I don't have a set of caliper's here.
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 01-25-2008, 10:23 AM   #2 (permalink)
14 mm
If the bolt head is 14 mm. I call them metric 3/8". They should measure 9.6 mm bolt. A 9/16" ring wrench often fits.
Airforce is offline
Similar Threads
2001 Front Right Shock Lower Bolt Won't Come Loose - Please Help shawv 1999-2007 General Questions 8 08-12-2006 01:48 PM
Lower frnt coil sprng bolt size? bork E-Series Vans 4 05-21-2006 12:41 PM
Problem with rear lower shock mount on '05 Sotoman 1999-2007 Upgrades and Aftermarket - General 4 05-26-2005 02:27 AM
Front Driver's Side Shock Replacement? Also bottom bolt/stud replacement for shock? kylep E-Series Vans 2 05-23-2002 08:04 AM
Fix Report: Snapped Off Lower Shock Bolt on Front Jim Swartz E-Series Vans 2 08-01-1999 06:01 PM
