'08-Up General QuestionsGeneral questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Is anyone else having an issue with the volume of the directions voice on their navigation system? It seems like every time I go to use my navigation system... I have to readjust the volume of the voice. It default back to very low after every use? I can't figure it out?
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
Have you tried to turn down the radio in the background when the navigation system is "talking"? That will actually turn down the nav volume. I noticed i was doing it subcontiously.
Jason
2008 F250 Lariat, 4X4 Off Road, Snowplow Package, Nav System, Tow Command
1995 F150 5spd 4x4
There is a volume control specifically for the navigation voice buried in the system set up options. Once the nav voice volume is properly set, the front radio speakers are attenuated when the nav voice speaks. If you are trying to adjust it with the radio volume control you will go nuts.
JC
F-450, 4wd, club cab, 4.88, KR, satellite, navigation, hi-capacity trailer towing, reverse sensor, memory mirrors/pedals/seats and tailgate step. Also Linex, TruckCoverUSA bed cover, CrimeStopper Remote Start and Alarm and a 25K Air Safe Air Ride 5er hitch.
Have you tried adjusting it via the INFO function when the radio is selected? On my X5 there is a feature that allows you to set the NAV voice relative to the radio volume. Cannot remember what it is called but it appears as an option when you press INFO with the radio playing and the NAV active.
________________________
Check out : Autopartswarehouse.com
