No right rear stop or turn signal - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 06-19-2017, 12:47 PM Thread Starter
Looking to see if anyone has had this issue before. I have a 2008 F-350 6.4 with a CM truck bed on it. ALL of the lights work except the right rear stop light and right rear turn signal. Is there a relay somewhere that might be causing this issue?
Jeff_B is offline
post #2 of 2 (permalink) Old 06-19-2017, 04:09 PM
klhansen's Avatar
My Photos: (180)
Sounds like a bulb or specific circuit issue to me. Could be a ground issue if the bulb works in the other side.
), AIS,
regulated return,
klhansen is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
