Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up General Questions
'08-Up General Questions General questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 11-01-2009, 07:55 PM   #1 (permalink)
compman72's Avatar
My Photos: (9)
Obtaining Winter Grill Cover
I will be traveling in the northern states this winter and being in the south - what is the best way to obtain a grill cover at no charge?
Is this something that needs to wait till its too late? Or just go out and buy one?
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Ride 3-20-09
compman72 is offline
Old 11-01-2009, 08:46 PM   #2 (permalink)
rock_doctor's Avatar
You need to buy one. Only those truck sold in the cold states get them for free. Just search the part number on the web for the best price. You are shooting for a price in the 70-80s. 8C34-19A413-AA is the part number, you have to supply the part number if you go to your local dealer. In honesty, if you are just going to be in those states in passing and do not plan to stay long i would skip the winter cold front. Just go. See what others say. You may just not need it for short term traveling. You may be able to get away with a piece of plastic or what ever covering the grill attached to the hood (only). Seems a shame to spend that much money just for a couple days use.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 11-01-2009, 09:11 PM   #3 (permalink)
I have to agree with rock doctor. Seems like a waste of 80 bucks if you're just passing through. My neighbor bought a new tv and I cut the box to be a little smaller than the grille. The box fits right behind the grille and even in the worst snow storms I haven't had a problem. Because I'm also a little vain, I spray painted the front facing side of the box so it's not even noticeable when it's in place. Sure beats the look of the big winter grille cover.
My$.02
Hunter40
2008 F-350 Lariat, 6 speed, Oxford White/Silver
Mods- Bedlocker, SEIC, Bedliner, Front windows tinted to match back windows, color matched door handles with no key holes, Harpoon Mod, Bedlocker electric tonneu, T-Rexx billet side vents, Rearview camera mirror added, Titan fuel tank.
Old Trucks:
2004 XLT Sport 6.0l- Buyback
2002 XLT 7.3l- Sold
Hunter40 is offline
Old 11-01-2009, 09:15 PM   #4 (permalink)
Why do you need to cover your grill?
444-4D is offline
Old 11-01-2009, 09:36 PM   #5 (permalink)
compman72's Avatar
My Photos: (9)
Not a bad idea - a piece of cardboard and some wire ties would do the trick if needed.
My$.02
Hunter40
08B07 Flash 1-16-09
Old 11-01-2009, 09:38 PM   #6 (permalink)
compman72's Avatar
My Photos: (9)
Snow packing of air filter/air induction:
If snow obstructs the air induction/air filter on the 2008 F-SuperDuty, there is a winter grill cover available to correct this problem. The cover is a customer purchase item, and must be installed as per the included instructions. The cover should be removed in temperatures above 50 degrees for normal driving, or 32 degrees when towing. Symptoms include a lack of power under acceleration and resticted air filter lamp illumination. Part number 8C34-19A413-AA. Broadcast Message 0284, 7323.
08B07 Flash 1-16-09
Old 11-01-2009, 11:40 PM   #7 (permalink)
How does snow blowing in from the grill make it all the way back to the air filter which is located in front of the passenger side of the firewall (am I correct on this location?)? I understand that the grill cover will help the diesel engine run more efficiently during the cold days of winter by keeping temps up, but the snow in the air filter warnings just don't make any sense to me???
'08 F350 FX4 is offline
Old 11-02-2009, 12:42 AM   #8 (permalink)
klhansen's Avatar
My Photos: (107)
You have obviously not spent much time where it's really cold and snowy.
Snow is still snow till the temp gets up above 32F, and since the engine is sucking in cold (below freezing) air, the filter isn't much warmer than what's coming in the grille. So the snow acts just like dirt, only it stays suspended in the air longer because it's less dense than dirt, and plugs the filter, posthaste.
I think you can get a cold front from Alaska Tent & Tarp in Anchorage for $40 or less.
Winter Fronts from Alaska Tent and Tarp
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 11-02-2009, 12:51 PM   #9 (permalink)
jsmichael's Avatar
I can attest that blowing snow will make its way to the air filter and clog things up. This happened to me last winter. The "Check Air Filter" light went on and I was able to contact my Ford service person who told me what the deal was with the snow getting into the filter box.
After I got home I took the cover off the air filter box and pulled out a bunch of snow. Of course the filter itself was wet, so I pulled it out and left it inside the house to dry. I then took our other car to an auto parts store and purchased a Purolator air filter to use until the Motorcraft filter dried out.
So, if you don't get the Winter Grille Cover, then at least pick up a spare air filter as insurance.
'08 F-350 XLT 4X4 6.4L PSD CC SRW LB, Line-X bedliner, UWS toolbox, Goodyear Wranglers, Marathon seat covers
jsmichael is offline
Old 11-02-2009, 10:00 PM   #10 (permalink)
StanMI's Avatar
Winter cover really helps with how fast the truck warms up on those COLD Winter days. Never had the snow issue with the air filter when not using it (knock on wood) .
2008 F350 Lariat CC Black two tone and darn near everything else.
StanMI is offline
Old 11-06-2009, 10:43 AM   #11 (permalink)
The grill cover works great. I live in Ma and used it last winter for the first time and it really makes a difference with warm up times. Also it protects mainly your aftercooler, also all the other coolers up front, from all the sand and salt on the road from getting kicked up and lodged into everything. There is still the open area in the bumper cut out, but the cover helps alot.
And the snow finds its way into the air cleaner by way of a snorkle that comes out of the filter housing and runs along the inside of the fender and ends about 6 inches behind the headlight. If the snorkle was not there, much like a did on mine and made a custom set up, you would not have to worry about it.
Evo B is offline
Old 11-06-2009, 05:13 PM   #12 (permalink)
If you're not going to install a cover carry a spare filter (hopefully one you bought somewhere on line rather than pay dealer retail price). My 2008 ingests light blowing snow like crazy. Before I learned my lesson I had the filter totally pack solid and spent big bucks at an out of town dealer for a replacement filter. Fords definition of snow country is pretty sad!
F-350 08 XLT, Job 3, 5/22/08 build, Auto, CC Long Bed, 3.73's. Dark Stone Exterior, Medium Stone Interior. Line-X, Buckstop winch bumper, Snug Super Sport Canopy. 2 German Shorthaired Pointers riding shotgun.
Stroked & Stoked is offline
