proper lube for door hinges
Morning All,
The local parts store said they were phasing out the ole white grease in a spray can that I've always used in the past for my door hinges. Is there a newer product that is better for hinges? I saw a silicon spray lube and a 'dry' spray lube at wally world, but thought I'd check with you folks to see what is advised (I got the last can of white spray grease from the parts store, but if there is better stuff I'll take it back before I use it).
08 F-250 CC KR 4x4
