'08-Up General QuestionsGeneral questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Has anyone noticed their fuel gauge slowly returning to full after refueling? I always leave my truck running and roughly five minutes after refueling the gauge is showing full. Outside of this the gauge(sender) appears to be accurate. Hand calculated mileage by the way is 12.3, 50/50 driving with 3500 miles on truck. As always thanks for your input!...
Chad
2008 F350 King Ranch Dark Copper/Pueblo Gold Dually 4wd(Manual) 4.10 Job#2 All options...
Sounds normal to me. My 2000 does the same thing. The guage is really dampened. Its very slow if you dont turn it off. If you shut it off and restart the guage should go to full right away.
Jay
Chad
Normal for all Ford vehicles...not just trucks.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Front Bull Bar w/ K.C. Daylighters * Draw Tite Fold Over Gooseneck * Gauges whited out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics *
I have not had my truck for long. I was wondering, why do you leave the truck running, and not shut it down?
I have never shut down any of my diesels while fueling...Sometimes for comfort(wife is with me), most of the time because I always idle my truck to cool the turbo(s). I guess I am really "old school" in the belief that it is also harder on the vehicle to cycle off/on in roughly less than ten minutes. My last Ford was a '97 and I could not remember how the fuel gauge(sender) behaved. Thanks for all the replies. Asking a simple question here saves me from jacking around with the dealer!
Chad
