Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up General Questions
'08-Up General Questions General questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 04-05-2008, 05:56 PM   #1 (permalink)
Rearview mirror removal?
Does anyone know the trick to removing the rearview mirror... the instructions for my new Gentex/Ford mirror simply state, "using screwdriver from the top, remove mirror".... I've played with it and played with it.... and I can't get it to come loose.... there has to be a trick to it. I don't want to shoot a windshield trying to get a stupid mirror installed.
Thanks in advance.
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 04-05-2008, 07:30 PM   #2 (permalink)
You need a small flat head and insert it from the bottom and push it in about 1-2 inches then very carefully twist the screwdriver a 1/2 turn(just like you would turn a screw) until the mirror is able to be moved up and off of the metal plate. Good luck.
TSN3982 is offline
Old 04-05-2008, 08:36 PM   #3 (permalink)
ok.... so I figured it out.... this mirror doesn't have the traditional release mechanism.... you put the screw driver in from the top and pry the mirror out toward you.... it has spring loaded clips on its side that hold it on....
RRose is offline
Old 04-09-2008, 10:00 PM   #4 (permalink)
Yep, that clip is a mother of a holder, isnt it?
2008 F-250 PSD 6.4L FX4
and several motorcycles.
tesnevo is offline
