replace 17" rim with 16" rim - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 10-05-2009, 02:41 PM   #1 (permalink)
I have a new 2009 xlt with 265/70R17. I was wondering if older 16" rims could be used with 265/75R16 tires? The tire diameter's come out to be the same, but is the bolt pattern and back spacing going to be different? The reason is that I need to run winter tires and they seem to be cheaper for the 16" rim.
Also, how annoying is the tpms light? I don't even know where it is, but any chance of getting away with just putting a piece of tape over it for winter?
jtdiesel65 is offline
Old 10-05-2009, 03:05 PM   #2 (permalink)
Nevermind, it took awhile, but I found it.
Apparently the answer is no as it won't clear the caliper.
16" wheels on 05+?
Old 10-05-2009, 08:26 PM   #3 (permalink)
Stymie's Avatar
that answer is 100% correct, 17 is as small as you can go
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 10-05-2009, 10:54 PM   #4 (permalink)
Charlie98's Avatar
Actually I was debating that very question... glad I didn't pursue it any farther!
Charlie98 is offline
