"Ticking" under the dash - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 07-02-2012, 08:43 AM Thread Starter
I have an odd problem which I have not seen before. Sometimes, I get a "tick tick tick" where the passenger side carpet meets the heater vent under the dash (glove box). It will happen with just the key on, and not running, or running.... makes no difference. Sometimes it's loud enough to be heard easily while driving 60 or 70 mph. Sometimes I can stop it by putting pressure on the carpet, or placing some sort of wedge (folded paper) between the carpet and the heater vent. I'm baffled.
Anyone have any ideas? I can't imagine what electrical component is behind there.
Thanks in advance.
Rick
renegade559 is offline
post #2 of 13 (permalink) Old 07-03-2012, 08:58 PM
senix's Avatar
Blend door motors.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #3 of 13 (permalink) Old 07-03-2012, 09:28 PM Thread Starter
Thank you for the reply, but I'm not sure what that means. Are there or is there a motor behind that area? The ticking happens with just the key on with heater and a/c shut off.
post #4 of 13 (permalink) Old 07-03-2012, 10:29 PM
hkyplr's Avatar
Send a message via MSN to hkyplr Send a message via Yahoo to hkyplr
Thanks in advance.
Rick
Sounds similar to the problem I had, could only hear it when I was just sitting there idling with the radio off or when the truck was off, key on. Thought it might have been something with the A/C or Heat but it would still do it when everything was shut off. I would also get hot air out of the passenger side vents when the a/c was on and it wouldn't regulate the temp very well. Took it to dealer and they told me the blend door was broken and replaced it. It sucks if you aren't under warranty because it is a dash out repair. Luckily I was under warranty.
2008 F350 CC Long Bed Lariat 4x4 SRW Job 1. H&S Mini Maxx running Mild tunes (for the moment) and S2L Trans tune. 4" Diamond Eye Downpipe back exhaust. S&B CAI. 5th Wheel Hitch. Front Receiver Hitch. Bakflip Tonneau Cover.
hkyplr is offline
post #5 of 13 (permalink) Old 07-06-2012, 10:13 AM
I had the ticking also and then the main controller failed and now my fans are blowing high. I'm not under warranty and I've left it like this. When I rustle up some extra cash I'm going to order a new unit (EXPENSIVE PART) and install it myself.
scotiadallas is offline
post #6 of 13 (permalink) Old 07-06-2012, 11:30 AM Thread Starter
Fortunately, I'm under warranty. 2010 truck with just 22k miles. I'll take it over on Monday and see what they have to say about it. My luck it won't "tick" while they're looking at it. And u probably know how the dealerships are............ if we can't duplicate the noise, we can't fix it.......... even if they know what it is.
2010 F-350 SD, 6.4
39' Montana 5th wheel, 15,200 lbs.
post #7 of 13 (permalink) Old 07-06-2012, 08:17 PM
My guess is that they are going to know exactly what it is - this seems to be an all too common problem with these trucks - I have read a lot about it.
D
post #8 of 13 (permalink) Old 07-10-2012, 04:37 PM Thread Starter
Well, as I was afraid, when I got to the dealer, it wouldn't make the ticking noise. The service writer said he knew what it was, but he couldn't schedule it in for repair till he actually heard it. I asked if they replaced both left and right side at the same time as long as the dash was apart, and he said he tries to do both. I asked him then what difference did it make which side it was, and he just said "I need to hear it myself". He also said I have 18k miles left on the warranty, so i have plenty of time for it to get worse.
2010 F-350 SD, 6.4
post #9 of 13 (permalink) Old 07-10-2012, 04:59 PM
hkyplr's Avatar
When mine was doing it and I had the a/c on I would get cold air out of the drivers side vents and hot air out of the passenger side vents. If yours is doing the same that might be another issue they would be able to verify in order to get the work done.
hkyplr is offline
post #10 of 13 (permalink) Old 07-10-2012, 07:03 PM Thread Starter
Actually, the air blows evenly out of both sides. There doesn't seem to be a problem with how anything works right now, just the noise from what sounds like the gears not meshing correctly.
2010 F-350 SD, 6.4
post #11 of 13 (permalink) Old 07-11-2012, 07:31 PM
My 2009 has the same problem. Everytime i went to the dealer for oil changes i told them to check it. Every time it would not make the noise while the tech or service writer was there. Very frustrating. I at least hoped i was getting it documented with them for when it finally failed. Well, last week it made the noise while pulling into the service dept. I left the truck running and brought the service writer out to hear it. He said, "oh yeah, blend doors. We'll order new ones and schedule the repair. It will take a week to get the parts and 2-3 days to do the repair." The noise seems to have a ticking sound, a grinding sound and a loud tapping sound that changes intermittently. The only consistent thing I found is that shutting off the truck and letting it sit a while would make the noise go away or change the next time the truck was started.
2009 F-250 Lariat 4x4
6.4PSD, Auto, 3:55
Crew Cab, short bed
100% stock
Oak Hill Farm is offline
post #12 of 13 (permalink) Old 07-13-2012, 05:56 AM
My truck added a new trick to it's list of issues yesterday. Driving home, with A/C on, it started blowing ICE cold air out the 2 drivers side dash vents but BLAZING HOT air out the 2 passenger side dash vents. Both temperatures were significantly hotter/colder than I have ever felt from it before. Since I have the option of driver/passenger heat controls, I tried to adjust the passenger temp, to no avail. I stopped for fuel, and when I restarted and left, all was working normally. Truck version of the "Raytheon Reset" we use at work on some of our elecronic systems? What was really wrong with the old-school, manual, heater, A/C and vent controls????
6.4PSD, Auto, 3:55
Crew Cab, short bed
100% stock
post #13 of 13 (permalink) Old 07-13-2012, 07:04 AM
senix's Avatar
A symptom of the same issue. Run the passenger side 10 deg colder and it will work.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
