Tire Size Calibration - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 07-03-2009, 08:37 PM   #1 (permalink)
I searched, but can't seem to get a direct answer...
I have a newly lifted 2008 F250 Diesel ext cab.
Just installed 37's on it.
Is there any solution to calibrate the truck to the 37's ?
Ford dealer says no.. Search here seems to say aftermarket only goes to 35's?
Looks like the Procomp only does 35's as well???
steves67 is offline
Old 07-04-2009, 01:42 AM   #2 (permalink)
dt75flh's Avatar
dealer can only program to a tire size that is offered in the ford truck line...
did you look into superlifts tru-speed?....
2008 F-350 SRW CC/LB 4X4 King Ranch 35" Toyos, 2.5 level kit, 4.10 gears, B&W turn over ball, Alpha liner,60 Gal Titan replacement tank, Edge insight gauges, air bags.
dt75flh is offline
Old 07-04-2009, 09:24 AM   #3 (permalink)
Ya, Looked at it..But their application guide says they only work through 2005 on the F250....So It appears that won't work?
steves67 is offline
