TPMS problems - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 10-21-2008, 05:25 PM   #16 (permalink)
can some one explain to me about the FOB. i just rotated my tires myself and dont want the light coming on
goodale is offline
Old 10-27-2008, 08:51 AM   #17 (permalink)
Martin #6's Avatar
I have the same question.
Early 99 F-250 4X4, built 9/98, 3:73LS, ATO trans with Chevron 30wt Drive Train Fluid, Garrett 38R BB ceramic coated 1.0 turbo, High Flow ceramic coated outlet, Non-ebv pedestal, BHA, Beans billet intakes, Teminator HPOS w/ R-IPR, Spearco 7.3 IC, 6.0 trans cooler, BWD ceramic coated bellowed up-pipes, DI regulated fuel return, AirDog, SWAMPS Stage II singles, BD Torq-loc, BD 4" in-line exhaust brake, 4" exhaust with ceramic coated downpipe, Live tuned by DP Tuner, Tymar, Racor CCV4500, Coolant filter, 203 T-stat, Pre and post pyro's, OilGuard by-pass filter.
SOLD
2008 F-250 4X4 Lariat CC. Job 3
No longer stock.
Martin #6 is offline
Old 10-27-2008, 10:28 AM   #18 (permalink)
Retraining the TPMS after rotation is only necessary if you have 17" or 18" factory wheels on your truck. It is not necessary if you have 20" factory wheels...
The instructions for TPMS retraining can be found in your owners manual...
TPMS reset tips
To reduce the chances of interference from another vehicle, TPMS reset should be performed at least three feet (one meter) away from another Ford Motor Company vehicle undergoing the TPMS reset procedure at the same time.
Do not wait more than two (2) minutes between resetting each tire sensor or the system will timeout and the entire procedure will have to be repeated on all four wheels.
A double horn chirp indicates the need to repeat the procedure.
Note:
It is recommended that you read the entire procedure before attempting.
Note:
To enter the reset mode, Steps 1–5 MUST be completed within 60 seconds.
1. The key must be in the ignition and the ignition turned to OFF/LOCK. Press and release the brake pedal.
2. Cycle the ignition from OFF/LOCK to RUN three (3) times ending in the RUN position.
DO NOT start the engine.
3. Press and hold the brake pedal for two (2) seconds, then release.
4. Turn the ignition to OFF/LOCK (
DO NOT remove the key.)
5. Cycle the ignition from OFF/LOCK to RUN three (3) times ending in RUN.
If reset mode has been entered successfully, the horn will sound once, the TPMS indicator will flash and the message center will display
TRAIN LF TIRE.
If after repeated attempts to enter reset mode, the horn does not sound, the TPMS indicator does not flash and the message center does not display TRAIN LF TIRE, seek service from your authorized dealer.
TPMS reset sequence
The TPMS system needs to be reset starting with the left front tire in the following clockwise order:
1. Left front tire
2. Right front tire
3. Right rear tire
4. Left rear tire
1.
Left front tire: Place the TPMS reset tool against the left front tire where the tire meets the rim, opposite from the valve stem (1) as shown. This is where the sensor is located inside the rim.
The tool needs to be held against the tire sidewall opposite the valve stem as illustrated with the arrow on the tool pointing towards the rim; do not use the tool with the arrow pointing away from the rim as it may not activate the sensor.
2. Press and release the green button and hold the tool to the tire sidewall until the horn sounds. The red light on the TPMS reset tool will illuminate while the tool is active. The horn will sound once within 10 seconds to indicate the process was successful.
Note:
If a double horn chirp is heard, repeat the procedure. If a single horn chirp is not heard, move the vehicle to rotate the wheels at least a 14-turn and repeat the procedure. If the horn does not sound while
attempting to reset any wheel, seek service from your authorized dealer.
3. Perform Steps 1 and 2 on the right front, right rear and finally the left rear tires.
Successful completion of the reset procedure can be verified by turning the ignition to OFF without the horn sounding. If two short beeps are heard, the reset procedure was unsuccessful and must be repeated.
If after repeating the procedure two short beeps are heard when the key is turned to OFF, seek assistance from your authorized dealer.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 10-29-2008, 05:00 PM   #19 (permalink)
If the rear tires are listed to have more pressure than the front you need to retrain when you rotate.
This also included the 20" wheels
2011 CC F350 Lariat 4X4 SB 6.2 Gas
Loaded Blue / Dark silver 2 tone
Trading 2008 CC F350 Lariat 4X4 LB 6.4 PSD
Loaded Black
Traded 2005 CC F250 Lariat 4X4 SB 6.0 PSD
Loaded Dark Stone/Arizona Beige
Traded 2003 CC F250 Lariat 4X4 SB 6.0 PSD
Loaded Black Traded 2001 Excursion Limited V10 Black/Arizonia Beige
Fords4ever is offline
Old 10-29-2008, 05:56 PM   #20 (permalink)
Correct... The only reason I said it is not necessary with factory 20" wheels/tires is they are 65 psi from the factory at all 4 corners...
Old 10-29-2008, 10:09 PM   #21 (permalink)
compman72's Avatar
My Photos: (9)
On my Job 3 truck there are 17" wheels and the door sticker shows 75 psi on each tire.
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
compman72 is offline
Old 10-30-2008, 01:27 PM   #22 (permalink)
You might've gotten larger tires with your truck, then.
Point is, the fob is only for "split" tire pressure, where the front is lower than the back. If your door jamb sticker says same for both front and back then hallelujah! You don't have to deal with that stupid fob.
timid1 is offline
Old 11-01-2008, 09:42 PM   #23 (permalink)
If anyone finds at SEMA or anther place an aftermarket solutio to adjsut the pressure at which the warnign come one. please post
I have BFG's that run at 50 psi max cold and the warning is on all the time
thanks
Ramb
2011 Superduty - Ordered 12/29/2010
2008 Superduty
1995 33' Formula Offshore, twin 525Hp SC's
2006 Yamaha Apex 1000cc
1970 Buick Skylark
1937 Ford
1930 Model A "50's Hotrod"
rambunctious is offline
Old 11-02-2008, 07:26 PM   #24 (permalink)
compman72's Avatar
My Photos: (9)
I did get the larger tires, and the window sticker calls for 75 psi for all 5 tires.
08B07 Flash 1-16-09
Old 02-10-2009, 08:24 AM   #25 (permalink)
sclevela's Avatar
not to thread dig but has anyone found an aftermarket tire solution yet?
2008 F-250 DIESEL - 6" SKY JACKER ON 37" PRO COMPS ETC.
sclevela is offline
Old 02-10-2009, 08:59 PM   #26 (permalink)
compman72's Avatar
My Photos: (9)
PVC pipe behind the seat with all the sensors inside it under pressure.
08B07 Flash 1-16-09
Old 02-12-2009, 12:50 AM   #27 (permalink)
Hmmmmm, my sticker in the jamb has the pressure for all tires at 75psi. So does that explain why I didn't get this TPMS tool w/ my truck? Also checked my tire pressure recently and my fronts are 64psi and rear is at 74psi....
Anyways the new suspension is going on and my new tires are rated at 50psi max w/ 3195lbs. I will just ignore the light. Never needed a light to tell me my tire pressures were low before.
firemansdiesel is offline
Old 02-12-2009, 11:03 AM   #28 (permalink)
Pappy19's Avatar
My Photos: (6)
That light has saved me and my wife's truck from going flat before I noticed it. I like them.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline
Old 02-12-2009, 11:11 AM   #29 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
Post Is your truck a job-1?
Someone can correct me if I'm wrong, but I think the TPMS were not installed on job-1 trucks or any DRW trucks.
Shawn
2008 F-450 JOB-1, 4 X 4 with 4.30's, auto with manual transfer case with factory cup holders. All options except sunroof and nav. Line X with Extra. 24K Draw-Tite Signature Series Fifth Wheel Hitch. 65 Gallon KSH Marine fuel/tool combo in bed. Viair 480C compressor with 8 gallon tank. Hadley Air Horns hooked up to Auto Mate alarm. Chime/Light Killer Mod. Polished Job-1 exhaust tips. Transmission upgraded to JOB-2 filter, pan, and lines. External filter eliminated.
PICTURES
GEARJAMMER is offline
Old 02-12-2009, 12:47 PM   #30 (permalink)
My truck is a late Job 2 truck. The test light (TPMS) comes on the display for a couple of seconds when I turn on the ignition. So, I know I have it.
