Trailer Turn and Brake lights don't work - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 03-15-2010, 01:52 PM Thread Starter
Ty Pope's Avatar
My truck has lights that work as does my trailer. However, connect the two and the trailer brake and turn signals don't work. I checked at the plug and get nothing from there except brake, charge, and running lights. I know there are 2 locations for fuses but haven't found any bad ones yet. What do I do now? Is there a single place that would control both sides at once? If there's a fuse under the hood that's bad, there'd have to be two of them bad. I've got a long trip coming up this weekend and need some fast assistance.
Thanks!
Thanks wp6529 and MPD56! Although I thought I had checked that fuse (missed it by one place... should have rechecked), that was indeed the problem. You guys have saved me lots of troubleshooting time. I am in the Air Force and am moving my family next week and couldn't figure out the thing but was willing to chance the trip with no trailer lights because I'm running out of time. Because of you two, it only took me 5 minutes to read the forum, 5 minutes to fix it, and 5 minutes to update this! Safe again!
Now: 2013 F-350 6.7 Platinum!
Had: 2007 F-350 6.0 Lariat
Had: 2008 F-450 6.4 Lariat
1992 F-250 Straight 6 XL (buy/fix/sell)
2004 F-350 6.0 Lariat
2002 F-250 V10 Gasser (never again) Lariat
2001 F-350 7.3 Lariat
1996 F-150 XLT
Ty Pope is offline
post #2 of 15 (permalink) Old 03-15-2010, 02:22 PM
Thanks!
Per my 2009 diagram, which should be the same, both trailer turn signal/stop/hazard relays are fed from 25A fuse F34 which is listed as being located in the "battery junction box" under the hood near the brake master cylinder. The trailer relays are also listed as being in this location. The parking light and charge relays are fed from fuses F42 and F44.
wp6529 is offline
post #3 of 15 (permalink) Old 03-15-2010, 03:12 PM
My 2008 diagram shows the same as wp6529 wrote. The control signals to both relays(20&21) comes from a smart junction box (SJB 11-3), so if both relays are working, I would suspect fuse F34. Let us know what you found.
- 2013
F350 CC 4X4 Lariat SRW, Black.
Ordered Dec 2012 - Built Jan 11th 2013 - Picked up Jan 31, 2013.
- 2013
Ford Edge
Built Nov 26 2013 - Picked up Dec 06 2012
-2008
F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29.
-1972
First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson).
-First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards.
-1982 - My Sister married a GM Sales Manager (He Retired, "Hello" Ford Super Duty, enough said, LOL).
-2003 - ZRX1200 (Some say "Mid Life", LOL).
-2008 - Jayco 313RKS 5th Wheel.
MPD56 is offline
post #4 of 15 (permalink) Old 03-15-2010, 07:16 PM Thread Starter
Ty Pope's Avatar
F34 was it! I checked the one next to it in error. I wasn't planning on rechecking it. You've saved me lots of time. Thank you.
1996 F-150 XLT
Ty Pope is offline
post #5 of 15 (permalink) Old 03-15-2010, 07:21 PM Thread Starter
Ty Pope's Avatar
1996 F-150 XLT
Ty Pope is offline
post #6 of 15 (permalink) Old 03-16-2010, 01:39 AM
Glad it worked out.
Thanks for the update.
- 2013
- 2013
Ford Edge
-2008
-1972
MPD56 is offline
post #7 of 15 (permalink) Old 06-22-2010, 06:05 PM
RF34's Avatar
New to the board. Found this thread with search. I had this same problem. Fixed! Thanks fellas. This site is great....
RF34 is offline
post #8 of 15 (permalink) Old 08-09-2010, 07:13 PM
I'm having issues with my running lights on two of my trailers, everything works on both except for running lights. Checked receptacle and no power on that terminal.Manual shows location 55 under the hood as Trailer tow parking lamps, but nothinig for running lights and this looks like a relay, so I can't tell if it is bad. Is this the relay/fuse responsible for my running lights and if so how do I test to see if it bad before purchasing a new one.
08 Super Duty
Thanks in advance,
Imspuds
Imspuds is offline
post #9 of 15 (permalink) Old 08-10-2010, 10:29 AM
Imspuds: I don’t have my diagram or manual with me at this time. But will look later if no one responds. I believe that fuse F42 supplies the power to the trailer running lights and the relay. Without the information beside me, if the fuse (F42) is good and you suspect the relay, there might be another relay the same be side it and you can swop them and verify that the relay is working.
- 2013
- 2013
Ford Edge
-2008
-1972
MPD56 is offline
post #10 of 15 (permalink) Old 08-11-2010, 12:31 PM
Imspuds: I donít have my diagram or manual with me at this time. But will look later if no one responds. I believe that fuse F42 supplies the power to the trailer running lights and the relay. Without the information beside me, if the fuse (F42) is good and you suspect the relay, there might be another relay the same be side it and you can swop them and verify that the relay is working.
MPD56,
Thanks for your time, found fuse issue, all is working properly.
Regards,
Impsuds
Imspuds is offline
post #11 of 15 (permalink) Old 08-28-2014, 02:01 PM
Same issue, F34 was it, relays good, everything works.
Thanks guys.
Kopperhed
2010 F250 S/C LB Lariat FX4 V10 Auto
Kopperhed is offline
post #12 of 15 (permalink) Old 10-08-2015, 04:57 PM
Guys i have 2005 F250 and a haulmark trailer, for some reason the LEFT Tail-light on the trailer for Brake and Blinker doesnt work, running lamps work fine and right side is also fine.
I've replaced both Relays under the Hood and i also inspected other fuses like F34 under the Steering wheel, looks fine.
What em i missing??
RearEngineDragster is offline
post #13 of 15 (permalink) Old 10-09-2015, 03:47 PM
What em i missing??
get a plug-in tester to fit whatever connecter is on your truck first, verify at that point first, that's how i found I wasn't getting juice to my trailer. after I got all the lights on the tester to light up at the connector, I was good to go.
Kopperhed
post #14 of 15 (permalink) Old 10-11-2015, 07:30 PM
There is a fuse for the turn/stop on each side.
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 136K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 147K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
2002 F350 CC DRW flatbed (originally pickup bedded) rebuilt & upgraded 4R100
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 164K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 241K (no engine repairs)
2007 BMW 550i 6MT 146K, Stuff breaking all the time that would last twice as long on a Kia or Hyundai, sad. Drives great though.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #15 of 15 (permalink) Old 10-14-2015, 08:37 PM
wingnut60's Avatar
Do the flashers work, or only on the right side?
Brake and blinker (flasher also) are the 2nd filament in the bulb--sounds like a bad bulb to me.
Joe
2010 F450 Lariat 4x4--died, but reborn
2009 F450 Lariat 4x4--died, scrapped
2007 F350 KR DRW CC 4x4-Gone to pasture
2015 Mobile Suites 38RSSA--hoping for another 10 years
2005 Mobile Suites 36TK3--traded, 10 years of camping memories
wingnut60 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
