Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up General Questions
'08-Up General Questions General questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 02-25-2008, 12:32 PM   #1 (permalink)
homepukes's Avatar
My Photos: (9)
Upfitter Switch Wiring Questions
I am trying to hard wire my radar detector to one upfitter switch and my Garman to another upfitter switch. I am wiring female connectors to the truck wiring so I can plug in my detector and Garman without destroying the male connector. My questions are:
1. Is using 10 and 15 amp switches okay? In otherwords does the detector and Garman just pull as many amps as they need or will there be 10 or 15 amps going to the unit at all times. I am pretty sure they draw only as much as they need and 10 or 15 is a max draw and will blow a fuse. I just don't want to find out the expensive way.
2. Where do I ground the wiring? For instance, the brown wire is the only wire and I assume the hot wire. I expected to see a ground wire with it but there isn't one that I can find.
2008 King Ranch CC 4X4
homepukes is offline
Old 02-26-2008, 10:04 PM   #2 (permalink)
Yes, whatever you connect will only draw what in needs to run. The upfitter switches are rated for the max allowable draw for the particular switch.
No grounds go through the upfitter switches. You simply connect the ground to any metal framework to connect to chassis ground. Several options are under the dash near the upfitter wires.
[img]/ubbthreads/images/graemlins/smile.gif[/img] Real trucks don't have spark plugs [img]/ubbthreads/images/graemlins/smile.gif[/img]
2008 F-350 CC DRW LB
Ordered 04/24/07 Delivered 06/23/07
Fantastic truck!!
DslDav is offline
Old 02-27-2008, 10:06 PM   #3 (permalink)
homepukes's Avatar
My Photos: (9)
Thanks for the info, I knew someone would know.
Old 02-29-2008, 10:40 PM   #4 (permalink)
homepukes's Avatar
My Photos: (9)
I got my radar detector and Garman hooked up to the upfitter switches today. The hardest part was getting the wiring through the dash and taking the dash apart without breaking anything. Everything works great and I don't have to worry about running the battery down if I forget to turn off equipment.
Old 03-31-2008, 08:12 PM   #5 (permalink)
I'm going to be installing an airlift kit - how hard was it to take the dash apart? I'd like to use the upfitter switches for this, as well, but don't think it is possible since I need momentary on and off switches.
'08 F250 Lariat, 6.4L, Auto, 4x4, CC, Short Bed
Edge Insight & Air Lift Super Duty Air Springs
Normal driving & pulling a travel trailer
CM71 is offline
Old 04-01-2008, 09:28 PM   #6 (permalink)
homepukes's Avatar
My Photos: (9)
To use the upfitter switches you don't need to take the dash apart. The only reason I had to take the dash apart was to run the wires behind the dash. I just wanted a clean look with no wires hanging out. There is a link on one of these forums about what the wires look like and which switch each wire goes to. All four wires are under the driver's side dash behind the parking brake. The switches work like the light switch in your home. Flip it up and you have power, down and it cuts power off. Turn the key off and the power shuts off even if the switch is up. It works great for stuff like a radar detector or GPS because it will not allow you to run the battery down. I am not sure how it will work for your application. If you need momentary power you can just move the switch up and down. It was really very easy to hook the wires up. Next to my power folding mirrors the upfitter switches are one of my favorite options.
Old 04-02-2008, 08:19 AM   #7 (permalink)
Harley350's Avatar
Would you be so kind and email me the link? Thank You!
Harley350 is offline
Old 04-02-2008, 09:03 AM   #8 (permalink)
homepukes,
Thanks for the clarification. We'll see how it goes once I get the airlift kit - I'd like to be able to use the upfitter switch to control the compressor (that sounds easy enough), but I will also have to figure out how to work in the air pressure gauge. The gauge might need to be in close proximity to the switch. I'd like to avoid mounting the airlift gauge with the supplied frame and instead mount the gauge in the blank panel beneath the switches, using an upfitter switch to control. I have the manual shifter for the transfer case, so there is just a panel and not an extra storage compartment in that area. If I have to use the airlift supplied frame for the gauge and switch, I'll probably end up mounting the whole thing in the console so it is out of sight.
CM71 is offline
Old 04-02-2008, 10:12 PM   #9 (permalink)
homepukes's Avatar
My Photos: (9)
I don't have a link because I don't remember where I got it. I do have it saved on my computer so if you email me at homepukes@aol.com I will send it to you.
As far as mounting something in the console you could just use the power point in the console instead of using the upfitter switches.
Old 09-28-2008, 03:16 PM   #10 (permalink)
Upfitter switch power loss
So where would you start looking if you had no power at any of the 4 factory wires behind the emergency brake?
jtment is offline
Old 09-28-2008, 04:30 PM   #11 (permalink)
it sounds like you are looking at the 4 pass thru wires from the engine compartment to the cab. If that is the case, look under the hood and they are taped up to the drivers side by the firewall. These are totally different than the upfitter switch wires. They are located behind the SJB AKA the fuseblock.
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 09-30-2008, 01:18 AM   #12 (permalink)
Hi there, no, I"m sure I got the right wires. At first, before I pulled down the fuse box, I did see the 4 wires under the hood. In fact I thought it weird that they were not shrinked up to avoid touching, then I found the other ends behind the fuse box, so I got the right ones. See my earlier post for an update. Thanks for your input. Those wires you are speaking of could easily be misleading..........
jtment is offline
Old 10-03-2008, 11:31 AM   #13 (permalink)
Not trying to insult your intelligence here- but I think there is a section in your manual that lists a website to go to that has all the info you need regarding the upfitter switches. I have not attempted to use mine yet, so I haven't been to the site.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
torino73 is offline
Old 10-08-2008, 08:56 PM   #14 (permalink)
Hey there, no insult taken at all. I did see the site that the owners manual showed, however, it only shows the exact photos I've already seen from other posters. The site isn't real clear on the exact location of these wires. Only to say they are behind the fuse panel. Actually they were taped to the back of the fuse panel. I never even thought to look. Funny, I had more trouble trying to figure out what you called these switches when searching through my owners manual. I was looking for aux switches and the like. Who ever would have looked up "upfitter" I just happen to stumble on that discription.
jtment is offline
Old 11-06-2008, 10:26 AM   #15 (permalink)
cbrinkhaus's Avatar
Stupid question to all of this. I'm looking to put some fog light in. How would I wire these to my upfitter switch? I have not done a lot of wiring so a step by step would help tremendously. Thanks in advance!!
-Chris
'06 F-350 6.0 XLT PSD Torqshift Supercab Shortbed Oxford White Line-X Bedliner 8' Fisher MMII AW Direct Hide Away Stobes Intake Elbow Sct Xcal2 from Innovative (econ, street, agg. street), MBRP 4" Turboback with cat delete pipe Intake Elbow from Aaron
cbrinkhaus is offline
» Network Links
»Ford Car Reviews
