Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up General Questions
'08-Up General Questions General questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 07-12-2008, 03:53 PM   #1 (permalink)
using trailer plug adapter
I have a 2008 F-350 with integrated brake controller. My buddy has a trailer with a small 6 pin round connecter. My I used an old adapter to plug into the large 7 pin on the truck. The brakes on the trailer locked up and the dash said trailer not connected. Can I not use an adapter or is there something wrong somewhere?
matt
classicbronco is offline
Old 07-15-2008, 09:35 AM   #2 (permalink)
Matt,
You should be able to use the adapter to a 6 prong plug. You will however need to check the position of the wires in that adapter. More than likely you'll have to simply switch two wires in the adapter so it is compatible with the OEM 7 prong. (assuming your 6 prong plug is wired standard) Using a test light, just identify each circuit on the seven prong and, one a time see which terminal that connects to in the adapter. Change the terminals marked in the adapter to reflect your truck's 7 prong.
fordson1 is offline
Old 07-15-2008, 10:28 AM   #3 (permalink)
RatherBNtheWoods's Avatar
There is two ways to convert 7-6 because of two different 6 pin plug pinouts IIRC. I think the center pin is different. One way it's the charge wire, the other it's the brakes. My 7-6 adapter came with instructions on how/what to change.
Our Raptor RV
12injectors so far
1 FICM
8 glow plugs
1 glow plug control module
1 HPOP
2 EGR valves, plus(cleaned 6 times)
EGR cooler
buzz flash replaced with
heat flash(seems to work quite well)
2 Batteries
8 Tires
Rear brake pads,,,At 105,000 miles.
Enough Rotella to float a boat!
New flywheel/clutch assy(possibly not needed)
Death wobble-FIXED!!ihope
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear,captains chairs, polished forged wheels, sunroof, tow mirrors, tow command brake controller, skid plates. Built May05. 4" turbo back w/modded OEM CAT,turboflow muffler, 100gal aux fuel tank, low profile black toolbox,5th wheel/gooseneck hitch, LineX(hate it), GlowShift fuel pressure gauge and fuel crossover tube. A real pig from a stop, but give me 10' and she'll lite'em up. 88K troublesome miles. Running fairly well for the last 20,000( Let us pray.....).
RatherBNtheWoods is offline
