Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up General Questions
'08-Up General Questions General questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 02-15-2008, 02:59 PM   #1 (permalink)
Cool What does it weight?
For some reason I can't find this anywhere. I have an 08 Supercab Lariet F250 Diesel with auto and I was hoping to find out roughly what it weighs. Anyone ever weight one?
08 F250 SC 4x4 LWB Lariet
kghenson is offline
Old 02-15-2008, 03:52 PM   #2 (permalink)
tarponteaser's Avatar
If you look at the door pillar, you should see the sticker with the Gross vehicle weight rating , and another with a the max weight of occupants and cargo. Subtract the max weight of occupants and cargo from the GVWR and you should have the curb weight as it left the factory.
I have a 08 crewcab F-250 4x4 KR loaded. With a bedliner sprayed in and 1/2 tank of diesel it weighed 8032.
08 F-250 CC KR 4x4
tarponteaser is offline
Old 02-15-2008, 09:26 PM   #3 (permalink)
My '08 6.4 with a Sungtop shell, CC 4x4 auto, full tank, 9060lbs CAT scale weight.
2008 F250 FX4 CC: Job 2
parcours is offline
Old 02-16-2008, 07:17 PM   #4 (permalink)
Stymie's Avatar
my CC SB weighted 8150 stock
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Try the SEARCH Button
Stymie is online now
Old 02-16-2008, 09:15 PM   #5 (permalink)
Send a message via AIM to Jerryc
The truck in the sig, full of fuel and with me and the wife, weighs 9860 lbs.
F-450, 4wd, club cab, 4.88, KR, satellite, navigation, hi-capacity trailer towing, reverse sensor, memory mirrors/pedals/seats and tailgate step. Also Linex, TruckCoverUSA bed cover, CrimeStopper Remote Start and Alarm and a 25K Air Safe Air Ride 5er hitch.
Jerryc is offline
Old 02-17-2008, 10:33 AM   #6 (permalink)
8140 with 3/4 tank, line-x liner, and less than 50lbs cargo. No passengers.
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Sequoia is offline
Old 02-20-2008, 06:13 PM   #7 (permalink)
9100lbs empty
I run mine across the highway scales. They are free and you can go when they are closed and it comes up on a display. I don't trust the door numbers cause I have found every truck I owned to weigh more. These are heavy trucks!
Rob
08 6.4 F350 SC LB DRW
dirtyharry is offline
Old 03-02-2008, 08:33 PM   #8 (permalink)
Ya'll got some heavy trucks, my 08' F350 is around ~6500lbs
08' F350 Reg Cab 4WD V10/6SPD/4.30LS
Ugly-Jeep-Truck is offline
Old 03-02-2008, 08:41 PM   #9 (permalink)
damn son, thats light. My 06 150 weighed that. Maybe thats why it was such a pig!
scrmn68 is offline
Old 03-06-2008, 08:18 PM   #10 (permalink)
Stymie's Avatar
the diesel and auto add at least 1000lbs over that gasser 6spd not to mention its a reg cab
17x9 Pro Comp 7189
Old 03-22-2008, 09:09 PM   #11 (permalink)
Curb Weight
My 2008 F-450 CREWCAB DRW 8'BED W/6.4L AND 4.30 , CURB WEIGHT WHEN SHIPPED WAS 8114LBS.
W5DVC is offline
Old 03-22-2008, 11:46 PM   #12 (permalink)
I have always wondered where Ford gets these shipping weights from. I would bet if you took your truck and scaled it your actual weight would easily add a good 1000 - 1200 lbs to Ford's 8114 lb ship weight.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 03-25-2008, 05:58 PM   #13 (permalink)
DFL
DFL's Avatar
In the People's Republic of Virginia (said with tongue firmly in cheek) vehicles that weigh over 7501 pounds do not get personal property tax relief. What does that mean? It means that you pay 100% of the tax, while those under the limit pay about half that. Why 7501? I don't know. For my truck it equates to a difference of about $800 a year. When the dealer filled out my paperwork they put a weight of 4800 or so (maybe dry weight?). The county folks that assess the tax didn't accept that and "figured" that my truck must exceed 7501. If I wanted it changed I had to get DMV to enter the true weight in the database. I could find NO information online or elsewhere of the actual weight of my vehicle that I could give to DMV. I could have hit the scales but two of the folks I talked to weren't sure if they could accept that. Mostly because (and this is the frustrating part) smaller vehicles are assessed on the actual weight of the vehicle (without passengers or cargo) while 3/4-ton and larger trucks are assessed on what the vehicle could potentially weigh to include passengers, cargo, and trailer. That meant I would be assessed at about 30,000 pounds (8k truck, 3k in the bed, and 19.5 on a 5-er). After fuming on this for a few weeks, I received a letter stating that my "official" weight was changed to 7500 pounds. I stopped calling and left it at that. I still don't know and at this point I don't want to know. Plausible deniability.
Jeff
2008 F-350 Lariat, CC, Short Bed, 6.4PSD
Gold on top, black on the bottom, camel on the inside
Go Hokies!
DFL is offline
Old 03-25-2008, 11:43 PM   #14 (permalink)
Leaving well enough alone was the best thing you could do. If you were to take your truck to the scales there is no way it would come in under the 7501 max.
Ford lists the base curb weight of a F-350 6.4L 4X4 CC SWB at 7648 lbs. Keep in mind that base curb weights are taken from XL trucks with no options and manual transmissions. So, naturally your loaded Lariat is going to weigh more.
Old 03-26-2008, 09:11 AM   #15 (permalink)
I weighed my F-450, a 4x4 auto heavily optioned Lariat with a full tank of fuel, hair over 9,000lbs. Far from your posted shipping weight.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC
http://community.webshots.com/user/C...host=community
CaptSkup is offline
» Network Links
»Ford Car Reviews
