What tires to go to after Conti's?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Old 05-05-2009, 09:51 PM   #1 (permalink)
I have a '09 F-450 which has the traction Conti's. As of right now I am not overly impressed with them. Seem to feel a little loose in the steering.
What do you all recommend as a good alternative replacement tire, needs to be a traction type tire.
Thanks!!
2009 F-450 Ranch King, CC, Dually, 4X4, LB.
1997 F-350 Powerstroke, 5-speed, CC, 4X4, LB, Programmer, 4" Magn-Flow SS exhaust, custom made 4" Cone air intake.
falcon428 is offline
Old 05-05-2009, 11:19 PM   #2 (permalink)
Charlie98's Avatar
I used to run Goodyear AP's until they discontinued them, after that I switched to Goodyear RT/S's, they are a fairly open tread and wore very well on my '99.
As soon as I wear out the BFG's my '09 came with, it's getting RT/S's! I've never been disappointed with Goodyears.
Charlie98 is offline
Old 05-06-2009, 08:12 AM   #3 (permalink)
davydee's Avatar
Falcon, just curious - what air pressure are you running? David
2009 F450 Pickup Lariat Plus w/Nav, 4X4 Off-Road Pkg, Rhino bed liner, 50 gal Transfer Flow fuel tank, 24k Reese Signature Series 5th-wheel hitch.
2011 MS 36RSSB3
davydee is offline
Old 05-06-2009, 08:32 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (44)
I'm a Michelin fan. Expensive, but a better value for the long run.
The F-450 has "real truck tires", which usually means you would use different tires on the steer and drive axles. The Michelin in size 225/70R19.5 for the drive axle is XDS2.
Michelin Americas Truck Tires XDS®2 Page
The Michelin doesn't make agressive tread tires for the steer axle. But their XRV is a good tire that will probably be what you want.
Michelin Americas Truck Tires XRV® Page
SmokeyWren is offline
Old 05-06-2009, 12:21 PM   #5 (permalink)
I always liked Michelin as well. I had great success with their AT series on my 2003 dually; however the AT2's that I replaced them with were a disappointment. I am going to try a set of Goodyear Duratracs on my 2008.
I think those commercial grade Michelins are still top notch skins to put on!
2008 F-250 Lariat SRW 4x4 CC SWB...
··· 6.4L & Torqshift w/3.73
··· Dark Stone Metallic / Pueblo gold
··· Readylift 3.5" levelling kit
... Toyo MT 315/70/18(bigger than 35-12.50-18)
----- --- BIG$HOW -------<Õ¿Õ¬
Bigshow is offline
Old 05-09-2009, 12:53 AM   #6 (permalink)
Charlie98's Avatar
...ah, I missed the '450' part.
You are still good to go with Goodyear.
Old 06-22-2009, 11:16 PM   #7 (permalink)
Ty Pope's Avatar
I went with Hancooks... Steering up front of course and drive tires in the back. I got them at Ford... They couldn't even put them on. They had to keep the truck overnight to finish up the front alignment... then they washed it for me... in the heat... and broke the front windshield. To their credit, they paid to have the windshield replaced. Still, a hassle...
Ty Pope is offline
Old 07-02-2009, 11:58 PM   #8 (permalink)
Just got an '09 450--steering seemed loose or too sensitive compared to my '07 dually--checked air in front tires, 80PSI. I think 85 is on the door sticker. Anyway, aired them to 100 and it tracks a lot better now. Still having some trouble with lanes rutted by semis.
2009 F450 Lariat 4x4
2007 F350 KR DRW CC 4x4-Gone
2005 Mobile Suites 36TK3
wingnut60 is offline
Old 07-03-2009, 01:55 AM   #9 (permalink)
Ohtsu R 128 front and rear. I get over 60,000 on them with any issues.
Stuper Duty is offline
