2008- 2010 General QuestionsGeneral questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
The owner card in my truck isnt in the glovebox, bought it used. I know the code is printed on the module, just wondering where to start looking. Thanks.
__________________ SOLD
-late 99 f-250 ext. cab shortbed 4x4.
-EGT/boost guages
-Pro-comp 4" lift, dual front shocks
-weld super-singles w/ 35/12.50 bfg A/Ts
-banks exhaust and downpipe
-zoodad mod
-'05 frontend.
-ATS housing
-gos racing headlight harness, silverstars
-DP Tuner
-4R100 HD
My son bought a used truck with the same problem as you, had to take it to the dealer to get the code, or find somebody who owns a reader, or find the previous owner and punch him is the face for not leaving the card in the truck when he sold it.
At least they left the owners manual and the window sticker. Never really figured out why people take that stuff out. What good does it do you once you sell the vehicle?
-EGT/boost guages
-zoodad mod
-'05 frontend.
-ATS housing
-DP Tuner
-4R100 HD
I think it's on the module up the firewall above the parking brake. At least it was on my '05, '03 and '01. Don't have that option on my '08 so that's why I'm not 100% on it's exact location. You should see some bold numbers on it , I think 5 of them, which is the code.
Look at the attached pics.
Look way up inside. The 5 digit # is the factory door code.
I had the dash apart for some other radio work and I figured I might as well document this.
Sticking the camera inside the dash was actually a lot easier than trying to see it by twisting my body in some weird position!
I couldn't even really see it with my eyes, but the camera was able to see the # pretty easily.
[FYI: The alarm will still sound if the doors are opened....and I now live in Alaska in case someone gets any stupid ideas with my code!!
NRA lifetime member....]
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/eXtreme tunes from Innovative,
but staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
Reason: Clarification for security
So does anyone have a definite on this? I can't tell if the pics in the post above are for an '08-'09. I'm guessing not judging by the truck listed in his sig.
I tried cycling the key on and off as instructed in another thread, no luck. I looked up under the steering column dash, pulled the glove box out, no luck.
Anyone know for sure where the computer module is? It's a brand new '09 and the stupid code card wasn't included with the manual.
I finally figured out my keyless entry door code!! After looking up under the dash with a mirror and flashlight several times, I could not find it there. I found the following number sequence listed on a forum somewhere. My wife gave up reading the numbers to me after a few minutes because “it’s too hot out here”. Great help she was!! Finally cooled off and had a neighbor help read ‘em to me. Only took another 3-4 minutes from where we left off before and, Voila!! The door unlocked. It sure beat depending on the Stealership! Hope this helps someone!!
This worked on my '00 Excursion which has the hardwired keypad (almost flush with sheet metal on door) as opposed to the later model wireless remote one's that are just taped or glued on to the door (protrude from the sheet metal by approx. 1/2 inch).
Michael '00 7.3 4x4 eXcursion 67K Miles - 2000+ Miles on WATF
Mine since 07/02/09 at 53.5K Miles - Autometer Gauges (EGT, Trans Temp, Boost, Air Pres.) - AIS (Ford Severe Duty) - BFG AT Tires (285/75 R16 BFG AT Load range 'E') - Harpoon Mod - ITP 7.3L Fuel Tank / Pre-Pump Kit (aka Hutch Mod) - On Board Air (Extreme Aire w/ 11 Gal. Tank) - Diamond Eye 4” Turbo Back Exhaust - 6.0 Trans Cooler - 2009 Side Mirrors - Modified B Codes - 30mm Rear Sway Bar - DPTuner F5 (Stock, Hi Idle, 60 Tow, 80 Econ, 120) - 203*Therm - DIY Coolant filter - ELC Coolant - Cryo powerslots & Hawk pads all around - SS Brake lines - AIH Delete.
Well I gave up looking and went to my salesman and told him it didn't come with the code. So he had me pull into service and they hooked me up to the computer free of charge. If I wasn't a customer it would have been $69.95.
for 08 and 09 models, it is much easier to find, remove the pass. kick panel and remove three bolts from the junction box module, pull it back and you will find the 5 digit code printed on the back.
