2008- 2010 General QuestionsGeneral questions related to 2008-Up Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Where is and how to relocate the temperature sensor
It's about time to put the Winter grille cover back on. When it's on it throws off the outside temperature reading. I get temp readings MUCH higher than the actual reading.
First where is and what does the sensor look like and how and where to relocate ??
2008 F350 Lariat CC Black two tone and darn near everything else.
I believe when you open the hood, it is on right side of the truck where the block heater cord is, just under the head light and above the bumper. It's a black plastic sensor. I'll try to confirm it when I'm near my truck
__________________ -2008 F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29. -1972 First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson). -First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards. -1982 - My Sister married a GM Sales Manager (He Retired 2007, "Hello" Ford Super Duty, enough said, LOL). -2003 - ZRX1200 (Some say "Mid Life", LOL). -2008 - Jayco 313RKS 5th (The kids won't move out of the house).
Thanks!!
Ford has a service kit available to relocate the sensor for folks such as yourself who are having issues with the EATC freaking out while running the winter cover and/or a plow. The part number for the kit is 8C3Z-14A411-C which has a MSRP of $48.53.
NOTE: If you are still under the original 36K warranty, you can get the issue taken care of under warranty using TSB 08-14-4.
07/21/08
LACK OF HEAT WHEN - SNOWPLOW AND/OR
WINTER GRILL COVER - EATC EQUIPPED VEHICLES
ONLY
FORD:
2008 F-Super Duty
ISSUE
Some 2008 F-Super Duty vehicles equipped with Electronic Automatic Temperature Control (EATC), may exhibit a lack of heat while snowplowing or using a winter grill cover. Symptoms may include higher than normal outside air temperature display readings. The abnormal outside temperature readings could lead to improper automatic temperature control function with inadequate heat provided to the cabin and/or undesired mode changes.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Relocate the outside air temperature sensor by following the instructions provided in the Service Kit.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
__________________ '04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD: Thanks for the interesting information. Do you know how I can tell if this was done to my truck? I’m sure it, isn’t because I have my grille cover on and my EXT temperature reading is way off. I’m bringing my truck to the dealer on Monday for power loss issues and it seems to never go well when I tell the Service Adviser that so and so has this on his truck and why do I have to ask for it to be on mine.
Added
You wouldn't have a link to see this part 8C3Z-14A411-C,
Thanks Again....MPD56
Added
Unfortunatly I have no further info or pictures of the actual part. I happened to remember seeing the TSB before and did a little digging to provide the info above. This seems to be one of those little known about TSB's since there is still quite a bit of talk about the issue yet there is virtually no info out there that a fix is actually available.
As for how to tell if it is already done... Well if you have owned the truck since new and have not requested it be done or seen any paperwork from your dealer with the above part number you can safely assume it has not as this is one of those issues that they will only fix if you complain about it. If you did not buy the truck new the S/A can check in OASIS when you take the truck in to see if it was done at any point under warranty. Other then that I would say that you are correct in assuming that it has not been done based on the issues you are having with your EATC.
Temperature -8F here and truck said +11F when up to temperature.
Just an update: I just got home from the Dealer after looking at my truck for power loss issues I had last Thursday. I bought up if my truck’s external temperature sensor had the sensor relocate kit installed on my truck? This affects trucks with auto cab climate control, when the grille cover is on or plowing. This was posted by PowerStrokeHD on an above post; I printed it out and produced it to the Service Adviser when it didn’t look like he was going to do anything. Boy my dealer just likes me pulling print outs, out of my pocket!! LOL. Also my intermittent power loss issue is a flaky EGR, new version EGR and relocate kit on order.
