If your mirror turn lights are working than the same thing will work for the fogs, just plug them in but you will need the harness and the switch. The plug for the harness is beside the drivers side headlight. Just run the harness from it to the fog light below and then to the passenger side. The mounting holes for the harness will line up. You will have to remove and reinstall a bumper bracket on each side to get the lights in. BTW, unlike the rest of the lighting system, the fogs will only work with the ignition on! I'm not sure about the auto on and that would be a nice feature! If you do it please let us know.
2008 F350 PSD XLT S/Cab 4x4 SRW L/B Job 2
2006 FR 29RLBS Wildcat
