08...Job2..."Tire Pressure Monitor Fault"......HELP - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 09-13-2007, 01:28 AM   #1 (permalink)
My truck is a job 2 2008 F350 FX4 which comes with this system. I have 37" tires. I DID NOT transfer the transmitters from each factory tire/rim to the after market rims and tires. I really would like to disconnect this system on the truck dash readout. Any idea's? THANKS!,Robert.
RKRacing is offline
Old 09-13-2007, 02:22 AM   #2 (permalink)
Re: 08...Job2..."Tire Pressure Monitor Fault"......HELP
No way to disconnect the TPMS system, as it is required by law on certain, if not all new vehicles now. You will either have to install the sensors in the new wheels or live with the light.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
Old 09-13-2007, 08:25 PM   #3 (permalink)
Do all the 08 trucks have this feature (dont know what a job 2 is)? I aired my tires down to 20psi to drive on the beach and get a low tire pressure light. Whats up with that? Robbie
2008 F-250 Superduty Black Extended-cab Short-bed XLT
2006 F-150 King Ranch Dark Stone Crew-cab Short-bed
ff1809 is offline
Old 09-13-2007, 09:03 PM   #4 (permalink)
Sounds like the system works. I'm sure you'd want to know if that tire was low going 70 down the highway with 18k behind you.
tzurick is offline
Old 09-14-2007, 01:20 AM   #5 (permalink)
"Sounds like the system works. I'm sure you'd want to know if that tire was low going 70 down the highway with 18k behind you
GOOD POINT !!! Thanks,Robert.
RKRacing is offline
Old 09-14-2007, 04:08 AM   #6 (permalink)
jjfertig's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RKRacing</div><div class="ubbcode-body">"Sounds like the system works. I'm sure you'd want to know if that tire was low going 70 down the highway with 18k behind you
GOOD POINT !!! Thanks,Robert. </div></div>
Sounds like something to go wrong the first time you change your tires. I'll stick with the good old $5 tire guage and walk around the truck every now and again.
2000 F350 XLT PSD, 4x4, 6 speed manual, 110,000 miles, Luk clutch, upgraded clutch fork, Ranchhand Front-End Replacement, 05 Grille, Clear corner lights, Bushwacker Pocket-Style Flares, 08 bed/tailgate/lights, ztech spray-in bedliner, BFG 285/75/R16E, KC foglights, running boards, XM Radio, Viper alarm, Leer 100XL.
1987 F-350 crew cab, 6.9, 5 speed, 4x4, stock
Proudly serving in the USN
Freedom isn't free: but don't worry, the US military is picking up the tab
http://img.photobucket.com/albums/v4...g/DSC01181.jpg
http://img.photobucket.com/albums/v4...g/DSC01183.jpg
jjfertig is offline
Old 09-14-2007, 09:06 AM   #7 (permalink)
Ramair's Avatar
i have a job 2 truck this feature was there already. i have 37"s we just swapped the bands which are wrapped around the drum of the wheel we had a little hassel since the wheels are 22"s. GM has a better idea ( my opinion)our H3 has them in the valve stem. wish i had this in my trailer tires!
08' FX4 CC short bed 6" Lift 37" Kumho's on Hoss 22's every option except PTO & rear ent. i don't ride back there! LOL
07' H3 lowered with 20's
97' Jeep TJ Sahara 6" lift Warn winch, Lockers, 4 wheel disc
2000SS Camaro conv.built motor, trans 12 bolt 600RWHP
87' Buick GN bone stock
69' SS Camaro Blown small block
57' Chevy 2 door wagom ZZ502 crate motor, 700R4 2004 Power Tour Long Hauler
71' Foose design Car Craft built SS/RS Camaro
The Insurance is killin me!
Ramair is offline
Old 09-14-2007, 10:23 PM   #8 (permalink)
Scott_M's Avatar
RKRacing, if you find a way to get around it I would like to know also.
2008 FX4 F350
ICON 4.5 lift
ICON dual steering stabilizer
Eagle Alloy 114 wheels
37x13.5 R18 TOYO MT tires
Painted N-Fab steps
T-Rex billet side vents
Recon smoked side marker lights
http://community.webshots.com/user/SM1856
Scott_M is offline
Old 09-15-2007, 12:58 AM   #9 (permalink)
My bad, I ment to type "I aired down to 20psi and did NOT get a light." You understand now? Thanks. Robbie
ff1809 is offline
Old 09-16-2007, 11:10 AM   #10 (permalink)
Scott_M's Avatar
I think Job #1 trucks do not have the tire pressure sensors. Job #2 trucks have the sensors. I believe, but not positive, Job #2 trucks are trucks produced after July 30.
2008 FX4 F350
ICON 4.5 lift
Painted N-Fab steps
Scott_M is offline
Old 09-16-2007, 12:48 PM   #11 (permalink)
That is right.
RKRacing is offline
Old 09-16-2007, 02:19 PM   #12 (permalink)
My understanding with most TPM systems is they look for a delta between the wheels. So if you air down all 4 tires at the same time it wouldn't alarm.
tzurick is offline
Old 09-29-2007, 12:59 AM   #13 (permalink)
I don't mind all that much about the sensors, although I don't case for them being banded around the entire wheel. Would have liked to see them done with a standard valve stem type...which would less severely limit my wheel choices.
08' F350 Reg Cab 4WD V10/6SPD/4.30LS
Ugly-Jeep-Truck is offline
