2008 F350 6061-T6 billet aluminum leveling kit....??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 10-16-2007, 09:31 PM   #1 (permalink)
I am considering installing a set of 2" 6061-T6 billet aluminum (lifetime warranty) spacers on my truck to level the front end. I am told that this kit does not require new (or extended) shocks and it will not negatively affect the ride or handling. The alignment is claimed to still be within factory spec after installation. The factory warranty is not supposed to be affected either. This kit would be installed on a 08 F350 4x4. Please let me know any thoughts or experiences you may have about this type of leveling kit. Thank you!!!
2008 F350 4X4 6.4L Lariat Crew Cab Torqueshift, Dark Shadow Grey, Loaded minus the sunroof, Edge Insight, B&W hitch, more soon.............
bearsfan1 is offline
Old 10-16-2007, 10:55 PM   #2 (permalink)
Re: 2008 F350 6061-T6 billet aluminum leveling kit....???
your caster will change; whether it will remain in spec or not, I'm not sure but I bet it will be fine. Not sure on the 08s but the 05s - 07s were on the line to begin with and with a spacer, some people noticed excessive bumpsteer and other issues, but then a lot didn't notice any difference either. You should be able to get away with your stock shocks. Bilstein makes a nice / killer shock for a 2" front lift that'll work well should you need / want new shocks. It'll ride better with them.
Best thing to do is just install them, get an alignment and see what they say. Most likely, you won't have to do anything, other than adjust the steering wheel.
Plenty of little goodies that the wife doesn't know how much I paid for... [img]/ubbthreads/images/graemlins/smile.gif[/img]
sredish is offline
Old 10-16-2007, 11:32 PM   #3 (permalink)
if these are what i think they are and go under the factory spring mount, then the axle will be shifted over to the drivers side unless you get a new track bar drop bracket.
and unless you have a fx4 truck (the shocks are a little longer for some odd reason and work well with the leveling kits) i wouldnt use the factory shocks.
2005 gto black/black - sold.............
2008 gl550 silver/black
2008 f250 cc fx4 silver & gray/black
z71burb is offline
Old 10-17-2007, 01:05 AM   #4 (permalink)
Even with the FX4 option the front shocks (don't know about the rears) are the limiting factor as to how much articulation there is. They top out (very hard on shocks) before anything else in the front suspension. I found this out while installing my F550 springs. I jacked the front up and let the axle droop (spring wouldn't come out). Then I disconnected the shocks which let it droop some more (still not enough). Next I disconnected the sway bar end links which finally let it droop enough to get the old springs out.
If street driven the stock shocks will work ok though. Just don't get your front end airborne while playing around.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
Old 10-17-2007, 01:08 AM   #5 (permalink)
While speaking with lift manufacturers I was told the 05/06/07 front ends only have 3 degrees of caster and that a simple 2.5" spacer leveling kit would take it all out.
Steve Urban
Semper Fi!
Old 10-17-2007, 10:40 PM   #6 (permalink)
Thanks for the replies. Sounds like the cheap and easy way may not be worth it after all.
Old 10-17-2007, 11:10 PM   #7 (permalink)
Of course they're gonna tell you that, they want you to buy the lift. I have 2.5 inch spacers and have had it checked afterwards for alignment and all is fine. No drivabilty issues or bump steer.
2005 F-350 FX4 XLT 4x4 CC/LB Torqshift with Diamond Back ATV Truck Cover, Zoodad Mod
Banks Power PDA with Monster Exhaust and Accufab intake elbow from Innovative Diesel
35x12.5x18 Toyo MT with 2.5" leveling kit, 2005 Weekend Warrior FB2200 for the toys
tzurick is offline
