2008 f450 tires 245/70/r19,5 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 12-07-2007, 05:11 PM   #1 (permalink)
Has anyone tried to fit 245/70/r19,5 tires on a f450?
I put 245/70/ r17 tires on my f350 with no probs but the f450 load range "G" tire make me wonder if they will fit.
WilliamD is offline
Old 01-16-2008, 05:38 PM   #2 (permalink)
the first problem is to find "G" rated tires in that size
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 01-20-2008, 11:38 AM   #3 (permalink)
The 245 tires need to be on a wider wheel, I think it is a 6.75 wide wheel. The 245 tires need the wider wheel for clearance between the duals, sidewalls will rub, and if mounted on the 6 inch stock wheel wear, and safety is a concern. This is the info, I received from two sources. G rated tires are readily available in the 245 size.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
