Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up Upgrades and Aftermarket
'08-Up Upgrades and Aftermarket Upgrading and adding aftermarket equipment to your 2008-Up Super Duty.
Old 12-31-2007, 01:03 AM   #1 (permalink)
2008 towing mirrors
Does anybody know if the mirrors used on the new 2008 trucks would fit on the 99-2007 models?
fordking1983 is offline
Old 12-31-2007, 02:11 PM   #2 (permalink)
BMacD's Avatar
Re: 2008 towing mirrors
Yes they will
Black 2002 F350 ext cab SB
BMacD is offline
Old 12-31-2007, 02:50 PM   #3 (permalink)
how does the wiring work out. I have an 02 does anyone know if they are round or flat connection?
2002 Liquid Gray F250 4x4 6 speed short box...trail fx 3" side bars, muffler delete, home made tymar, DP 60 hp PCM flash, Isspro Pyro and Boost on the A-pillar, Rhino lined westin brush guard, TT mirrors, Draw-tite remov-a-ball gooseneck hitch, 37% tint on the front 25% on the back, Rough country 1.5" leveling kit.
bboteler is offline
Old 12-31-2007, 04:39 PM   #4 (permalink)
you have to rewire things. the plugs are different. i have mounted mine, but i am waiting for warmer weather before i start wiring them up.
02 white CC LB SRW 7.3. Edge J/A, AFE Stage II, 4" straight exhaust, WW, billet TC, TransGo Tugger II, 203 therm, AIH delete, HX mod, engine boot kit, ZooDad, 2.5" front shackle, 2.5" front springs, SS brakelines, 5" rear block, rear airbags, ProComp traction bars, 37 12.5R17 ProComp X AT's on 17x8 ProComp 7089, painted door handles, billet grille, DEH-P650 Pioneer head unit, 400watt amp, 10" sub, 08 mirrors.
01 Yamaha Raptor 660 - the other money pit SOLD
vintage road bicycles - the new money pit
pictures
harmonjustin is offline
Old 01-01-2008, 08:53 AM   #5 (permalink)
Did you have the 02 mirrors before or just the paddle style also what does our connection look like on the 02, I have opened it up yet, been at work a lot, not time to look. I'm thinking of just upgrading to the 02 tow mirrors but don't know what the connection is (round or flat)? Thanks
bboteler is offline
Old 01-01-2008, 12:26 PM   #6 (permalink)
I just installed a set of the 08 towing mirrors on my 05. I had the towing mirror, but wanted the bigger convex mirror on the 08s. I did not get the power fold or extend. The 08 mirrors use a square type connector, but it is a high-density design. I clipped the connectors of my original mirrors and soldered them to the new ones. The wiring color codes were the same, but I have one problem.
1. Heated mirror ok
2. Turn signals ok
3. Up/Down ok
4. In/Out backwards
I am going to check the pin out on a 08 switch to see if that will fix it.
Iron2 is offline
Old 01-01-2008, 12:37 PM   #7 (permalink)
william_04_X's Avatar
i put a set of 08's(non-power fold) on my buddies Y2K..all he had was the 3 pin round connector in the door..i too clipped all the connectors and soldered..had to add wires for markers, signal, and heat..
the mirror right/left controls are backwards, the motor location has been changed in the mirror on the 08 style...there is an aftermarket fix in the works which will add relays in the doors to correct this..
to the Op:, yep ,they fit perfectly..
04 EB X w/03 PSD
Southern Nevada Power Strokes.Org
william_04_X is offline
Old 01-02-2008, 02:58 PM   #8 (permalink)
Delwars's Avatar
My Photos: (5)
Were is the cheapest place to get the 08' mirrors w/ power telescope and fold???
1999 F-250
DP F5
4" Straight Pipe Turbo Back via Farm Boys Diesel
Homemade two tank WVO system.
"It's always better to be judged by 12 than carried by 6!!!"
Delwars is offline
Old 02-11-2008, 04:48 PM   #9 (permalink)
uloadit's Avatar
I just pick up 08 mirros ,the left /right controls cant you just switch the wires around at the switch on the door? if not how do you hook up the relay or where can i get the relay at
2002 F350 XCAB D.R.W.auto 4x4 manual lock.P.S.D.3.73 axl(code-VDH2) (BONE STOCK).15 m/gal empty- 12/gal 19,500Lb piller gauges (ISSPRO)pyro,boost,trans temp-under dash cub mount (V.D.O.)oil Page Ranking,volt,eng temp.AIS air filter,baldwen spin on trans filter,RACOR INTERCEPTOR kit primary fuel filter (and fuel heater)6.0 transmission cooler,
uloadit is offline
Old 02-11-2008, 06:21 PM   #10 (permalink)
Roy_Boy's Avatar
The solution is to disassemble the mirrors so you can access the wires right near the in /out motor. Clip them both off and reverse/ reconnect. I've done 3 sets of these mirrors this way, no relays required.
I played with the wires at the switch, it is not possible to change it there due to how the mirrors are wired, from what I could tell...
Roy
2004 F350 super cab short box dually
One of a kind
6.0L, 6speed, 4x4, 3.73 axles
US gear exhaust brake
Custom SCT,tuned by Tadd
Engine#3- 6398 miles (still running great)
Haulin' More than most of y'all
02 VW Beetle TDI 5 speed
Roy_Boy is offline
