2009 F250 Crew Cab 4WD - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 09-29-2009, 09:43 PM   #1 (permalink)
I bought a 2009 F250 Crew Cab 4WD back in July. I had previously owned a 2008 F350. I tow a 27 foot gooseneck flatbed trailer. My F350 did not sag in the rear end when loaded with the trailer. My F250 seems to drop right down when i am hooked up with a loaded trailer. What can i do to make the rear end on the 250 the same as what i had on the 350?
JPALLISON01 is offline
Old 09-29-2009, 11:19 PM   #2 (permalink)
smotrs's Avatar
My Photos: (16)
You'll probably have to change out the rear springs to match that of the 350. The 350 had a heavier set of springs on the truck then the 250.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
smotrs is offline
Old 09-30-2009, 09:14 PM   #3 (permalink)
vanstruck's Avatar
Firestone Ride Rite Air Bags
vanstruck is offline
Old 10-01-2009, 08:38 AM   #4 (permalink)
senix's Avatar
add air bags or add a leaf, personally I would look at the add-a-leaf. Easier to maintain.
You will need to replace the u-bolts. u-bolts should only be used once.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is offline
Old 10-01-2009, 09:49 AM   #5 (permalink)
smotrs's Avatar
My Photos: (16)
Personal opinion, I would go with the air bags myself. They will give you the support you need when loaded. At the same time, you can maintain your 250 suspension which will make the unloaded ride much smoother.
Shaun
Line-X bedliner
smotrs is offline
Old 10-01-2009, 01:14 PM   #6 (permalink)
Martin #6's Avatar
I went with the Firestone Ride Rite Airbags.
Early 99 F-250 4X4, built 9/98, 3:73LS, ATO trans with Chevron 30wt Drive Train Fluid, Garrett 38R BB ceramic coated 1.0 turbo, High Flow ceramic coated outlet, Non-ebv pedestal, BHA, Beans billet intakes, Teminator HPOS w/ R-IPR, Spearco 7.3 IC, 6.0 trans cooler, BWD ceramic coated bellowed up-pipes, DI regulated fuel return, AirDog, SWAMPS Stage II singles, BD Torq-loc, BD 4" in-line exhaust brake, 4" exhaust with ceramic coated downpipe, Live tuned by DP Tuner, Tymar, Racor CCV4500, Coolant filter, 203 T-stat, Pre and post pyro's, OilGuard by-pass filter.
SOLD
2008 F-250 4X4 Lariat CC. Job 3
No longer stock.
Martin #6 is offline
Old 10-01-2009, 02:37 PM   #7 (permalink)
Firestone air bags. With one caveat. Don't expect any shop, no matter the price, to do a leak-proof installation. While I'm sure it can be done regularly I have not experienced that and have had to re-do two installs with new air lines and fittings. On one I had to relocate the Schrader valves because they put one right in line with the spare tire crank hole.
Just be ready to re-do it right yourself or have a buddy who knows how. If they're installed carefully and approached as if they're going on an aircraft rather than on a pickup truck they will give good long reliable service. If the air lines are routed around any which way for expediency of installation they are guaranteed to give problems.
jliltd is offline
Old 10-01-2009, 11:05 PM   #8 (permalink)
rod.10853's Avatar
I thought the only difference between the 250 and 350 were the
blocks and the spines, but the leaf packs were the same. In any
event, I have been hauling fill dirt and gravel in the back of my
F250 over the last few months, and I have to say it was down
right embarrassing how bad the truck sagged with even a yard
or so of fill dirt back there. So, I put a 2" add-a-leaf in the rear
and I love it! It did stiffen up the rear a little bit, but I like it
the way it is now. It feels like a big truck should feel. And,
it doesn't rock back and forth like crazy now when I back out
of my driveway at an angle!
I had ordered air bags before I got the add-a-leafs, but the
order went on "back order", so I canceled and moved on
the add-a-leafs. I'm glad I did! No filling up bags, no leaks, and
no failures. I like the Firestone bags and may use them some
day. But the add-a-leafs are doing awesome on my truck. I just
need to stiffen up the front end now. It bounces even with
the camper package coil springs. I'm sure some Bilstein shocks
with help with that ...
p.s. By the way, no complaints from my wife regarding the ride
with the add-a-leafs, either. She says she thinks it's better
now, too.
Rodney
08 F250 CC LWB 4x4 PSD, 6 SPD-Manual, 3.73 LS
2.5" Leveling Kit / 2" Superlift Add-a-Leaf
18" MT Classic II Wheels / 35" Toyo MT tires
SnugTop Truck Cap/Shell
Xtreme Liner
rod.10853 is offline
Old 10-06-2009, 12:41 AM   #9 (permalink)
I bought F350 rear leaf blocks from Readylift for my 08 F250, it now sits level when loaded and has a slight rake to it when unloaded which I like. Didnt do anything to increase capacity but got rid of the sagging rearend when loaded.
____________________________________
2008 F250 SD Lariat 4x4 CC SB w/ 6.8 V10 4.10's
SOLD: 2003 F250 SD Lariat FX4 CC SB 4x4 w/ 6.0 PSD/Automatic. 2001 F250 SD Lariat 4x4 CC SB w/ 7.3. 2000 F250 SD XLT 4x4 CC SB w/ 5.4
Car nut!!! Also have '65 Mustang Conv.(K-code), '67 Shelby GT-500, '70 Mustang Boss 302, and a '66 Corvette 427/425 Conv. All usually in various states of disrepair!
magstar67 is offline
Old 10-08-2009, 10:11 AM   #10 (permalink)
Timbrens, anyone? Vehicle Suspension Kits - Timbren Suspension Enhancement Systems
Worked well for me on my '04 and '07 trucks.
2009 F450 Lariat 4x4
2007 F350 KR DRW CC 4x4-Gone
2005 Mobile Suites 36TK3
wingnut60 is offline
Old 10-11-2009, 09:13 PM   #11 (permalink)
Has been that way for years. 350 blocks should get your height back. Airbags is the best way to do it if you can.
2009 F250 KR FX4 6.4 NAV
Pretty much stock for now
Sold: 2004 F350 with 35's and stuff
Truck PICS iconMore PICS
Money Pit: 2005 Rubicon with 33's and stuff
Old Man's Truck: 2008 F250 6.4 reg cab
Old truck: 2003 F250 with hardly any stuff iconPICS
barneybadase is offline
Old 10-12-2009, 02:42 PM   #12 (permalink)
Check out TSB 07-7-2 which deals with rear ride height issues for 5th wheel towing. The TSB calls for replacing the 2" rear axle spacer with the 4" spacer.
2010 F350 CC, SRW, SWB, 4x4, V-10,Torqshift, 4.10LS, XLT, Bright Red, Med Stone 40/20/40 Pwr Seats, Single CD with Sirius and Sync, Tow Command, Pwr Scope Mirrors, ESOF, FX4, Chrome Tube Steps, Cab Lights, 18" OWL A/T Tires, Forged Aluminum Wheels, Snow Plow Prep Pkg, Reverse Sensors, Advance Security Pkg.
Remote Start, Rhino Liner.
2005 Open Road 357 5th wheel.
Reese 20K Select Series 5th wheel hitch w/ round tube slider.
shark1955 is offline
Old 10-12-2009, 03:47 PM   #13 (permalink)
NEVERSWEAT7's Avatar
X2
I had them in my 350 and loved them. get the in cab dual controller. No muss no fuss. You drive down the road and adjust as neccessary. Counterbalance pneumatic check valve keeps the balloon effect from happening and all is perfect.
2010 F-450 King Ranch (loaded)
Alpenlite Portofino RL36
Reese 24K Sig Series fifthwheel hitch
Reese 30K Sig Series gooseneck hitch
Aerotank 65 gallon tool/tank box ( on timer)
Eclipse AVN726E Nav
NEVERSWEAT7 is offline
Old 10-12-2009, 06:30 PM   #14 (permalink)
add a leaf or even better, bags if you wanna spring the cash.
inino is offline
Old 10-12-2009, 06:39 PM   #15 (permalink)
Don't timbrens work better as overload springs, rather than leveling a truck for towing?
dzzz is offline
