Just to let you all know I finally went to the dealer and ordered one. I had the coice of a 3 button or 4. The four being the remote start button. I did not have high hopes that the remote start would work with the ford bronze system but figured i would try it. I'm happy to report that the key works perfect to lock/ unlock and also the secureloc/pats key. No joy on the remote start though. At least now I got rid of the big remote and only have the small one. btw the cost was $99 for the key.
Alex Strand
2010 F350 6.4 DRW 4x4 FX4. Lariat ultimate package, homelink, 3.73 limited slip, line-x bedliner. white platinum metallic tri coat with 2 tone adobe and camel leather interior. Born on date: 09/2009 Delivered 5/27/10 with 43 miles
Currently 76K on the clock as of may 11'
Mods:
*Scan Gauge II
*CAT/DPF stock exhaust
*Recon cab, mirror, and fender lights
*High idle Mod
*20K Curt 5th wheel
*100 gallon aluminum flush mount fuel tank with direct fill into factory tank.
*Flush mount tool box
*Tinted windows
*Airlift bags on rear with compressor and 2.5 gal tank
Mod List: -51 gal RDS direct fill auxillary fuel tank -SEIC High Idle -H&S Black Maxx Running the Hot Damn +300 Tune -S&B Dry CAI -Diamond Eye 5" Turbo Back Race Exhaust -Custom 10" Sub Box Behind the Center Console -Coastaltech SYNC-LP1 Lockpick -Westin Bull Bar -Westin Taillight Guards -Recon LED Smoked Dodge Cab Marker/Clearance Lights -Billet Fender Vent Inserts -Zone Offroad 4" Lift -20x10 BMF Novakane 8's -35x12.50r20 Nitto Trail Grapplers
-'11 Super Duty Rear Seat Cargo Tray w/410W Power Inverter
If I remember my 06 correctly it would not because the 07 down trucks had that plastic flair piece on the ignition would not allow the key to go all the way in.
Alex Strand
Mods:
*Scan Gauge II
*High idle Mod
*20K Curt 5th wheel
*Tinted windows
Yes it is one piece key and remote. It works perfectly with the 2010. I just had it cut and then I programmed it. The only thing that I have not gotten to work is remote start. Still have a few ideas on that that I need to try. Btw I'll put up a pic of th key and the part number as well.
Alex Strand
Mods:
*Scan Gauge II
*High idle Mod
*20K Curt 5th wheel
*Tinted windows
Line3500: Do you know how to reprogram the remote start for a shorter startup delay? I have the owners manual for it, but since it was factory installed, they didn't include the installation manual. Mine is setup for a 30s delay. I'd like it to be much shorter.
Tvandyck7, yes I do. Mine was dealer installed and had that 30 sec delay. I changed it to no delay. It's either on or off. But with it off it turns on and there is about a 5 sec delay before it cranks. I have found this is plenty of time for the glow plugs in our trucks. I started it a few times with temps in the low 20's. Pm me your email address and I will PDF you the install manual so u can change it.
Alex Strand
Mods:
*Scan Gauge II
*High idle Mod
*20K Curt 5th wheel
*Tinted windows
Do you have pics of the remote yet? Sounds like I need one of these.
07 F-250 Harely 8 inch fabtech, 38 inch toyo's, 20 inch wheels, traction bars, air bags, 4 place gauge pod, bullydog triple dog, 5 inch exhaust, amp steps and more to come.
08 F-450 4.30 Gears, SCT Livewire with Custom Tunes, AFE Intake, DPF Delete, 5 Inch Exhaust, 8 Inch Fabtech with Bilstiens, 22' Wheels with 37' Toyo M/T, Amp Steps.
11 F-450 Trying to decide what to do with this one!
Thanks Alex! That will help me out alot. 30s is way too long. I don't use it much since it takes so long.
here are the pics of both sides of the key. still working on the part number.
Alex Strand
Mods:
*Scan Gauge II
*High idle Mod
*20K Curt 5th wheel
*Tinted windows
well its possible. I am going to reprogram my remote start to having to press the remote button twice and see if that makes any difference. the way that the new fob is set up is to press it twice. I will report what happens. i have the bronze kit but i think the only difference is that the gold kit has a security system and remote start combined in one module.
Alex Strand
Mods:
*Scan Gauge II
*High idle Mod
*20K Curt 5th wheel
*Tinted windows
PM'd. I'm looking forward to changing it. It's getting cold!
