Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up Upgrades and Aftermarket
'08-Up Upgrades and Aftermarket Upgrading and adding aftermarket equipment to your 2008-Up Super Duty.
Old 08-11-2008, 03:25 AM   #1 (permalink)
20X10 doable on a stock height
4X4 F350SD
What tires would be the best, if so?
or would a leveling kit or higher be needed..thanks ahead
dirteeboy808 is offline
Old 08-11-2008, 09:23 AM   #2 (permalink)
Harley350's Avatar
20 by 10 is not enough information. Which size tires will you be using?
Here's what My bud uses on his stock F250 2008--- Fronts rub during a tight turn but only alittle. A level kit would prevent any rubbing
35x12.50R20 Section Width:--Section Width:12.51 in318 mm
Rim Diameter:--Rim Diameter:20 in508 mm
Overall Diameter:35.02 in889.50 mm
Sidewall Height:--Sidewall Height:7.51 in190.75 mm
Radius:--Radius:17.51 in444.75 mm
Circumference:--Circumference:110.0 in2794 mmRevs per Mile:-Revs per Mile:593.9
Harley350 is offline
Old 08-11-2008, 06:50 PM   #3 (permalink)
sorry about that it was late and I was pretty delirious...
So with the leveling kit 12.5 is widest width for the tire without rubbing..if I run a 20x10 wouldn't it stretch the tire a little allowing more clearance?
Old 08-11-2008, 07:50 PM   #4 (permalink)
Stymie's Avatar
a 10 inch rim is what you are supposed to run with 12.5's or at least a 9"
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains
Try the SEARCH Button
Stymie is offline
Old 08-12-2008, 12:10 AM   #5 (permalink)
since everyone are running 9", does anyone know if the 10" with a -13 offset create a problem with clearance or should it help it since it's pushed out a little further
sorry for all the questions, new to going up, used to to going down......
