Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up Upgrades and Aftermarket
'08-Up Upgrades and Aftermarket Upgrading and adding aftermarket equipment to your 2008-Up Super Duty.
Old 02-10-2008, 11:01 AM   #1 (permalink)
AggiePSD's Avatar
2WD Low with ESOF
Can we do like the older Superduty's (2000, etc.) and splice into wiring for the solenoid controlling front hub vacuum and put in relay or switch to achieve 2WD Low?
Like this: The Mustang Shop
Also, are any vacuum/wiring diagrams available for this truck yet, such as for the ESOF system?
Thanks,
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
Truck & Other Pics - More Truck & Other Pics
1968 IH Travelall 4x4
Work truck - 2008 F-350 6.4 PSD XL Crew Cab, Long Bed, Single Wheel, Torqueshift, 3.73LS, 4x4
AggiePSD is offline
Old 02-12-2008, 08:17 AM   #2 (permalink)
AggiePSD's Avatar
I guess nobody stuck with ESOF likes 2WD Low?
Travis
AggiePSD is offline
Old 02-12-2008, 12:12 PM   #3 (permalink)
Stymie's Avatar
not really, if i need low range, i probably want 4wd too.
The only time i use 2wd low is in my Early Bronco, and that is using only the front axle, for turning purposes.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains
Try the SEARCH Button
Stymie is offline
Old 02-12-2008, 01:26 PM   #4 (permalink)
Aggie, I go through lots of sand and water in Fl. and mostly use 4 high. I see you're in Texas, would you use it on wet roads or off road? Snow?
Sorry no help to you but just curious about the application.
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Sequoia is offline
Old 02-12-2008, 06:43 PM   #5 (permalink)
AggiePSD's Avatar
Mainly for manuevering heavy trailer loads in and out of tight spots on soft ground. I realize I can use 4wd off the road, but the truck always has plenty of rear wheel traction with a heavy pin weight, the trailer tires just like to sink down and it's hard for the truck to move the trailer. With 2WD low I can turn sharper and better without the binding of the front axle engaged, while having that extra low gearing to move the load.
Same thing applies on pavement, except that we don't have any concrete around here that I have to manuever trailers on that is very steep and would cause a large load on the truck.
Travis
AggiePSD is offline
Old 02-14-2008, 09:49 AM   #6 (permalink)
Aggie, I'm with you.... I would like to make this mod to my truck as well. I had the manual 4WD in my last truck and used 4W Lo all the time to back my heavy 5h wheel up and into my driveway. Having the ability to move heavy loads, especially when you have to do a lot of manuevering of the truck comes in really handy at times.
Come on all you modification pioneers, jump in there and find a solution for the rest of us
2008 F-350 6.4 Job 1 SRW LWB 4x4 Lariat Crew Cab, Dark Blue Pearl/Pueblo Gold, With all options except the tailgate step and cab clearance lights.
Truck PICS
Duane_Miller is offline
Old 02-14-2008, 07:12 PM   #7 (permalink)
taboky's Avatar
In my '04, I just unplugged the vacuum soleniod for the hubs. Then used truck as manual 4x4. I would lock the hubs when I needed 4x4, leave unlocked (Auto) rest of time. Throw it into 4lo when backing toyhauler uphill. When doing so, with hubs on Auto, i had 2lo. Haven't looked to see if same setup on the '08 yet.
'08 F350 Lariat DRW CC LB Job 3 Black/Silver
towing a '07 Raptor 3712TS toyhauler
with a '02 Kawasaki Nomad Dresser in the garage
taboky is offline
Old 02-14-2008, 08:51 PM   #8 (permalink)
AggiePSD's Avatar
I think it is the same setup at the hubs. I didn't think about doing that, and it should work. I think I'll do it for now.
Not sure how that effects the transfer case, is it electronically shifted or vacuum? If vacuum shifted maybe it would be a good idea to plug those hub lines until we know exactly how the vacuum system is setup?
I guess I really just need to find time to crawl under the truck and figure this all out. Lord know you can't look from on top of the engine and expect to find anything...
I may do what you're talking about for the time being until I can find a proper wiring/vacuum diagram. Then I can do it all from the flick of upfitter switch #4. That way I would still have 4wd with the hubs in auto. Lazy, I know, but the switch would just be neat!
Travis
AggiePSD is offline
Old 02-15-2008, 03:29 PM   #9 (permalink)
Aggie, try this.....
Full Pull Towing - Welcome
No info on the site about model applications, but this may be something to look at...
Sequoia is offline
Old 02-16-2008, 03:24 PM   #10 (permalink)
AggiePSD's Avatar
I'm pretty sure that's basically the same thing as I linked to in my first post. I would have to imagine the 08 is different. Somebody is just selling a kit for way too much money.
Travis
AggiePSD is offline
