Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up Upgrades and Aftermarket
'08-Up Upgrades and Aftermarket Upgrading and adding aftermarket equipment to your 2008-Up Super Duty.
Old 07-17-2008, 05:19 PM   #1 (permalink)
Question 37's on stock crew crab
Has anyone tried to fit 37's (37x12.5x20) on stock 20 inch rims with no lift?
08psd4x4 is offline
Old 07-17-2008, 09:06 PM   #2 (permalink)
Stymie's Avatar
wont happen, i have 37's on six inches, and i am pretty sure i could flex them into the fenders.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains
Try the SEARCH Button
Stymie is offline
Old 07-17-2008, 09:12 PM   #3 (permalink)
I think you could pull it off on both the 7.3 and 6.0L models but you would have to buy a cheap level kit, do some trimming, and definately use the stock wheels. As for the 6.4L models, that might be a problem, but I would stick to a 285 or 305 size tire to keep better fuel mileage.
2006 F-250 SC FX4 Off-Road. 6.0L. Hypertech Stage III. Airaid Intake. Poweraid TAG. Muffler/Kitty Delete. Daystar Level. 35X12.50R20 Toyo Open Country M/T.
wareagle08 is offline
Old 07-17-2008, 09:47 PM   #4 (permalink)
I've seen a guy on another site running rockstars and 37s with a leveling kit. I have 35s on my truck without a leveling kit, I think you could run 37s but if you flex them at all, they'll probably hit somewhere.
mattmeyer05 is offline
Old 07-18-2008, 11:05 AM   #5 (permalink)
there is a guy on f150online with 37" with no lift on the factory 18" wheels, looks ok but not prportionate to the truck, it needs a lift for the looks.
Smoke
Smoke650 is offline
Old 07-19-2008, 12:22 PM   #6 (permalink)
I have 35's without a lift and it is the max. They even rub on the radious arms when i turn hard backing up. 37's , no way. You would destroy your inner fender wells and you wouldn't have any turning radius at all.
JoeVacs is offline
Old 07-19-2008, 12:24 PM   #7 (permalink)
Hey Stymie, what kind of fender flairs are those? They look great
JoeVacs is offline
Old 07-21-2008, 01:41 AM   #8 (permalink)
Stymie's Avatar
they are the bushwackers OE's
17x9 Pro Comp 7189
Stymie is offline
Old 10-23-2008, 04:20 PM   #9 (permalink)
I have no rubbing with 35 x 13.50's on 18's discount says 37 will fit and looking at all the space I have I believe them.
2008 F-350, Crew Cab, 6.4
MOUNTAINMAN010 is offline
Old 10-23-2008, 07:58 PM   #10 (permalink)
APEX320's Avatar
10 Years of tire experience says NO WAY they will fit, and if they by chance do fit the first bump you hit ( like when backing out of your driveway ) you can say bye bye fenders. I have a 8" BDS 4 link kit with 37" Toyos, I have room for 38" but if I hit hard when turning itll hit. Just my 2 cents
2008 FORD F350 WHITE
8" BDS 4LINK LIFT
37" TOYO MT'S
18" DEVILSLIDES CHROME
SCT TUNER
AFE STAGE II WITH BOOST TUBE
KENWOOD DNX8120 EVERY ADD
FAB FOUR BUMPER W LINEX COLORMATCH
BEAMER HID LIGHTS
4 KC 8" HID LIGHTS
ION CHROME MIRROR LIGHTS
LED INTERIOR LIGHTS
BUSHWACKER POCKET FLARES
HUSKY LINERS
LINEX BOX
MARATHON SLED DECK, W 10FT RAMPS
APEX320 is offline
Old 10-23-2008, 08:44 PM   #11 (permalink)
You can fit 37s with a 6 inch, a member on FTE has done so. Truck fits 34" stock so maybe a four inch would allow 37s
Carl Lassiter is offline
Old 10-24-2008, 09:09 AM   #12 (permalink)
well it can be done i finally talked to someone whos done it no rubbing
2008 F-250 Lariat Crew Cab
Two Tone Dark Shadow Gray and Tan,with 6.4L OHV Powerstroke Diesel and TorqShift 5-Speed Automatic, 3.73, Heated Leather Seats,Moon Roof,Custom Sub Box, Memphis 10" Sub, Hatchie Bottom Max 4 Neoprene Seat Covers,5% tint on back,20% up front,5% top and bottom windshield brow, Security System, Line-X,Stealth Reverse Lights, 20's
MORE TO COME
08psd4x4 is offline
Old 10-24-2008, 10:39 AM   #13 (permalink)
This is my truck with 37" BFG's on stock 18". I'm running a Bilstein leveling coils and 5100's up front and a readylift 4" Block in the rear. I'm rubbing a little on the inner fender on hard turns, nothing a little trim wouldn't take care of.
bulldogce is offline
Old 10-24-2008, 12:43 PM   #14 (permalink)
Could I do the same with stock 20's and a level kit
2008 f250 King Ranch, leveling kit, T3 front repacement bumper
rmitch5 is offline
Old 10-24-2008, 10:10 PM   #15 (permalink)
On my 88 F350 CC 4WD, I had 9.00 and then 11.00R16 Michelin XLs on stock rims, with just a 2" add-a-leaf at both ends. With the 9.00s, no contact. With the 11.00s, slight rubbing on front leaves at full steering lock. The front bumer was replaced with something that sticks out for a winch.
The 9.00s were 36X10"; the 11.00s were 38.7X11".
You might look at Michelin 275/80R20 XZLs to work if you have 8 or 9" wide rims (the factory rec. rim is 9"). They are 37.0" tall, 11.0" wide and carry 3970 lb at 60psi at 68mph. Very strong all steel construction, aggressive but long-lasting tread. They weigh 72 lb.
I don't think they'll fit a stock 08 truck without mods, though.
Charlie
diesel Landcruiser & M37; 05 Unimog U500 w/Unicat camper
Charlie is offline
