Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up Upgrades and Aftermarket
'08-Up Upgrades and Aftermarket Upgrading and adding aftermarket equipment to your 2008-Up Super Duty.
Old 01-29-2008, 03:10 PM   #1 (permalink)
6" Lift, Vibrations
I just had a 6" Rize installed on my 08, F-250 cc swb kr. It looks great and drives like stock but when I accelerate from a dead stop I can feel a vibration/shimy and it stops fairly quickly once the truck starts to run...I dont know if they should have installed shims or a bracket to reduce the angle of the drive shaft. Anyone know what can be done to eliminate this? Did the shop install the lift correctly? Thanks for any insight.
Outnumbered is offline
Old 01-29-2008, 08:16 PM   #2 (permalink)
Stymie's Avatar
the vibration on take off is axle wrap. If the vibes continued on, i would point to the carrier bearing or such. The only way to fix it is traction bars.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Try the SEARCH Button
Stymie is online now
Old 01-29-2008, 09:22 PM   #3 (permalink)
coupe5oh's Avatar
With that much lift it should have shims to drop the carrier bearing. Most lifts should include them.
SOLD
-late 99 f-250 ext. cab shortbed 4x4.
-EGT/boost guages
-Pro-comp 4" lift, dual front shocks
-weld super-singles w/ 35/12.50 bfg A/Ts
-banks exhaust and downpipe
-zoodad mod
-'05 frontend.
-ATS housing
-gos racing headlight harness, silverstars
-DP Tuner
-4R100 HD
New Truck
-2008 Crew Cab 4x4, Lariat, 20s, stock for now.
http://community.webshots.com/user/coupe5oh
coupe5oh is offline
Old 01-29-2008, 10:48 PM   #4 (permalink)
I've got an 8" Rize 4-link up front and OUO Traction-Blocks in the rear. It's a block with an incorporated traction bar. Also have a fully adjustable carrier drop.
Even with traction bars & carrier drop tried in many positions, I have that same shudder on take-off. My shudder is the same unloaded, or pulling 6k+. The load didn't matter. Got no worse with the trailer hooked up, even with all that weight. It is NOT axle wrap. It's the carrier wobbling. Crawl under your truck, grab the driveshaft, shake it, and you can immediately see how much play the rubber on the 08 allows, compared to previous years. My installers and I tried the carrier out of an 04. It changed the characteristics of the vibe, but it is still present. It basically stiffened it up, but introduced a new vibe from 20 to 23mph, roughly. The kind of vibe that makes your side mirrors vibrate when you look at them, like a subwoofer would, but very mild and subtle compared to the take off shudder which was still 90% present.
On a recent trip to Maine, (and VERY cold temps), the rubber in the carrier stiffened up quite a bit, and the take off shudder was about 50% less. As soon as I returned to warmer climates, it's right back to the level it had been before.
In a few weeks, I will be switching out the rear "traction blocks" for ones that will change the pinion angle a bit, to see if that helps. We are working on the issue and hopefully will have it solved soon.
Since you're at a 6" lift (front), the rear lift on yours would only need minimal carrier shimming at most. For mine with an 8" (front, rear lifted to level the truck out), the adjustable carrier drop may have been TOO much, (meaning, the minimum drop of 1.5" may have been to much, in this case).
Hope that sheds some light on the situation. It would be worth checking into a good set of traction bars for piece of mind. I wouldn't run a lift without them.
ZeroOne is offline
Old 01-29-2008, 11:54 PM   #5 (permalink)
Stymie's Avatar
odd because when installed myfabtech bars, the vibration was gone....
17x9 Pro Comp 7189
Old 01-30-2008, 08:04 AM   #6 (permalink)
Thanks for all of the input, I am going to check with the shop for the traction cars, any idea of cost on these and/or sugeestions of which ones to buy? Does it matter which brand? To have a brand new truck and feel that vibartion is annoying. Will update when and if I can resolve this...
Old 01-30-2008, 08:09 AM   #7 (permalink)
I just got off the phone with the shop and they said the RIZE blocks are angled so no shim was necesary. they are pricing the traction bars now....I would have thought someone woould have suggested that given how obvious it is..
Old 01-30-2008, 10:45 AM   #8 (permalink)
Stymie's Avatar
i paid 700ish for my fabtech's. i believe they have the best design. if someone tries to tell you they don't have them out for the 08's pm and i'll tell you how to order them
17x9 Pro Comp 7189
Old 01-30-2008, 01:17 PM   #9 (permalink)
Take a look at Rize..you will be surprised at the quality and superior design
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 01-30-2008, 02:17 PM   #10 (permalink)
Stymie's Avatar
Cary
the ony difference i see is the rize is square tube, the fabtech are round. both are full floating, hiem joint setups.
The rize is almost almost 200 more than i paid for fabtech.
17x9 Pro Comp 7189
Old 01-30-2008, 02:51 PM   #11 (permalink)
they are pricing pro comp, rize and fab tech for me now...I will post the differences, stymie-did it completely eliminate the that vibration?
Old 01-30-2008, 03:08 PM   #12 (permalink)
PSDfreak's Avatar
Someone please correct me if I'm off base....But even with the tapered blocks at the axle, might you still need to shim the center support bearing down (carrier)? I have seen this SAME issue on two other Fords first hand (a 95 and a 99) and both had SAME symptoms after having a lift installed. BOTH had tapered blocks to adjust pinion angle, still had a little wiggle from a stop. Installed Procomp shims at the center support bearing and the vibration is completely gone.
I apologize if I am off track here, just trying to make sure you exhaust all options before dropping ~$700 for tractions bars if they are not necessary.
Good Luck
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 01-30-2008, 03:57 PM   #13 (permalink)
Stymie's Avatar
i would be suprised if the lift kit he has didnt include a carrier bearing drop, but its easy as hell to check. just crawl under it. And yes, my vibration is gone.
17x9 Pro Comp 7189
Old 01-30-2008, 07:00 PM   #14 (permalink)
I spoke to RIZE, the suggested the carrier drop bearing would solve the issue and i am going to add the traction bars from them as well because of the boat i tow (14k) it was strongly suggested to keep the axle from twisting under that extreme load. So it is all ordered as well as the AMP research steps so it will go back next week. I will post once it is done, both items combined should take care of it.....keeping my fingers crossed..
Old 01-30-2008, 07:08 PM   #15 (permalink)
Stymie's Avatar
whats the price on the rize bars
17x9 Pro Comp 7189
Similar Threads
Pics of 7"+ lift and 37" caryt Power Strokes 1994-1997 Upgrades and Aftermarket 12 01-31-2008 08:05 AM
Forgive me, Im new. Whats a "Hutch" and "Harpoon" Mod? keith_1963 Upgrades and Aftermarket - General 1 11-21-2007 01:41 PM
"4psi electronic lift pump continued" (need keep on truckin's expertise) fishinfreak 7.3L IDI Diesels (Not Power Strokes) 2 09-27-2007 02:12 AM
8" Lift for Ex with 38" Swamper Questions cack999 Power Stroke Excursions 1 09-27-2001 09:23 PM
