...I'm not too sure if I received the the wrong size steps and wrong instructions on accident. All part numbers seemed to match vehicle according to webssite, but steps were too long and ran into other problems
Amp Research Folding Steps for 2008 Ford F-350 Supercab
Problem:
Instruction manual included with Amp Research step setup only had wiring diagrams up to 2007 Solution: Download 2008 specific manual off the Bestop or Amp Research website, but keep the other manual as you'll need it for other parts of installation <C'mon Amp to charge over 1k for steps and the instructions are all mixed up>
Problem:
Both L&R steps were too long and would bind on the front and rear sheetmetal body pinch points Solution:
Trim at least 3.5" to 4" off to steps so they can recess into space between cab and frame. Play with the spacing, remove the plastic end piece and cut as needed. <How much did I pay for these steps and I can't get the steps cut to the right length, hmmmm>
Problem:
Wiring instructions says that all trigger wires are to be sent through grommet on passenger side only, although wire harnesses guide each trigger wire to driver and passenger side accordingly Solution:
The door ajar or trigger/step activator wires can be found on each side accordingly so no need to extend driver side to the passenger side
Problem:
Wiring instructions say passenger side trigger wire will need to tapped into all white wire and all yellow wire leading to the rear of the vehicle...<read the instructions you'll know what I mean> Solution:
The step does not fold with yellow wire hooked up, so leave it off and only hook up the all white wire to trigger wire <purple with black stripe>
Problem:
Steps would work in reverse order, open the door steps would go up and close the door steps would go down Solution:
Reverse the orange and white wires that plug into the motors, either cut and splice or make it nice and push the connecters out with a pick and reverse in plug
Overall Experience:
The quality of the steps, motors and construction are OEM or equal quality, but it bothered me that I would have to trim a 1k+ product and by so much. The wiring diagrams were sort of correct, although if instructions are year specific they should at least have the correct wiring diagrams. The wiring into the plugs into the motors were also reversed <switch the orange and the white>
I have these steps on my 2008 Crew Cab. They are excellent. Great quality, strength and very good clean looks on my lifted truck. Perhaps the issues dirteeboy808 is having is isolated to Supercab models only.
Black 2008 F250 loaded Lariat/ 6" ProComp Stage II lift w/ control arms and traction bars/ 37x13.50x22 Toyo MTs/ 22x11 black XD Monsters/ painted Bushwacker fender flares/ Bully Dog PMT/ Amp Research power steps/ smoked Recon LED lights all around
I've tried to contact Bestop and AMP-Research to let them know what's up, but haven't had any reply...It also wouldn't be feasible to return these from Hawaii
It just sucks to pay over 1k for steps and have to custom fab some things to fit...overall though the quality of the steps, motors, etc are excellent...I'm in know way trying to put them AMP-Research down, just an FYI to them
i just installed a set of these on a buddies 2006 cc lb - great product. install took less than 2 hours. the instructions we had were dead on. sorry about your luck!!!
its making me think twice about getting a set for my 08!! i love the steps on his truck, but i like the fact that the bars i have on my truck help protect the paint chips from things getting flung up by my front tires.
What island are you on? or where are you in Hawaii?
2004 F-350,Lariat,CC,6.0L,6spd.,FX4,
Power Rear Slider,Power TT Mirrors,Moonroof,4.5" DR hanger kit with DR shocks,Welds w/315's Toyo MT's,MBRP SS Turbo back exhaust..
Take a look at these CRE Rocker Flares. I have run them on every truck I've had in the past few years and they really do work great for keeping your rockers looking new. I just threw a set on my 08 last night. They run $200 a set.
Hello.
My name is Bruce and I am the Amp-Research technical support contact. I am sorry you had trouble with our product. From what you posted I think you may have purchased the Power Step for the 99 - 07 Super Duty Crew Cab. The 2008 Super Duty Power Step uses a totally different wire harness and controller. In addition, we make a different size step for the Crew Cab VS the Super Cab.
Again I apologize if you could not reach us. We are here to help. If you have any questions or need assistance please feel free to call Tech Support at 888-983-2204 or 949-221-4181.
i dont believe you can run these and the amp steps together
I'm pretty sure you can run both. The rocker flares mount to the outside of the pinch weld and the Amp steps mount back behind so there is not interference. I've seen both on super duty's around here. CRE is located in my town so everyone runs the rocker flares.
__________________ 2008 F350 PSD CC SB Lariat - 8" Fabtech Radius Arm kit, Icon Remote Res shocks, 20" black KMC Monsters on 38x15.5" Toyo MTs, Icon dual stabilizer, Spartan 210, S&B CAI, Flo-Pro exhaust, RBP Grille, N-Fab steps, CRE Rocker Flares, Recons, custom mesh side vents, Alpine IVA-W505 DVD with Sirius and back-up cam, Alpine 5x7s, Fosgate amp and 10" sub 2008 Harley Softail Deluxe - Black and chrome, 16" apes, fishtails, slammed 2008 YZ450F
but the mounting hardware for the steps uses the pinch welds. i dont know how that would affect the mounting of the rocker flares
The rocker flares bolt to the outside of the pinch weld. I looked at the Amp installation manual for the '08 and it looks like all I'll have to do is drill out the aluminum mounting plate on the rocker flares so I can run the bolts through the pinch weld for the idler and motor assemblies. I'm about to order a set so I'll know soon and post it.
