Originally Posted by jrz1
I have the same problem with a set of steps I tried to install today. The driver's side works fine but the passenger side won't operate with the white and yellow wires connected. I know it's the right set as it says 2008 F250 right on the wire harness. I tried the motor on the other side and it worked fine so must be the wiring or the controller. I tried one black/purple wire as indicated above but it doesn't work.
I'm sure I'll get an answer this week but it is frustrating that there is no tech support on weekends when most people are probably trying to install these.
Contact Bruce @ Amp Steps he was a big help.
Sorry man I don't think I can be of much help as I had to wire in a 2007 style steps into my 2008. Although you can do a volt test and see if the there's a signal/power going through the wire when the door is open and closed. I believe it's the open door chime/sensor that activates the step to go down
