Aux Tank on Upfitter Switches - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 10-27-2009, 09:21 AM   #1 (permalink)
warweasel's Avatar
Hi, I'm buying a slightly used 09 F350 PS DRW with a 110 gal auxiliary tank. In pictures (I haven't seen it yet, I'm in Kuwait), it looks like the switch for the tank is mounted to the right of the driver's knee area. I have no experience with the extra tanks. Would it be possible to rewire that switch to one of the upfitter switches so there's not some extra crap hanging on my dash? Thanks!
warweasel is offline
Old 10-27-2009, 12:03 PM   #2 (permalink)
NEVERSWEAT7's Avatar
Thanks for that great idea.. I have an auxilliary tank and just asked about it. have no answer yet but I am looking forward to the outcome.
2010 F-450 King Ranch (loaded)
Alpenlite Portofino RL36
Reese 24K Sig Series fifthwheel hitch
Reese 30K Sig Series gooseneck hitch
Aerotank 65 gallon tool/tank box ( on timer)
Eclipse AVN726E Nav
NEVERSWEAT7 is offline
Old 10-27-2009, 10:31 PM   #3 (permalink)
using the upfitter switch is a nice idea, but I have a tendency to turn mine on when i remove a cup or something from the cup holders under the switches. Just throwing out an experience. It could cause a problem when hooked to a fuel pump.
first_ford is offline
Old 10-28-2009, 12:40 AM   #4 (permalink)
FF, you bring up a great point. I talked with my dealer Bobby W. today. The truck is back. he said it is mounted in such a fashion that I know where it will be but it is outta sight. It has a timer on it for the 15 minutes. I just have to reach up under the dash and wind it up. I like the idea.
For me it takes the guesswork out of ...I better check and make sure I shut it off. Also added was a fuel gauge for the auxilliary tank which sits low in the center (I think). Bobby told me but until I see it I am not really sure. I dig that idea, knowing where that tank sits so I can estimate pretty close to how far I can realistically drive or when I should fill that tank up.
One thing for sure, with this set up, I do not have a reason to ever run out of fuel.. other than both gauges breaking which is highly unlikely.
The Eclipse entertainment system should be mounted this week. Maybe Friday I could end up with a truck.. maybe Monday.. either way, it is getting close. and of course, I am getting excited.
Eclipse AVN726E Nav
Old 10-28-2009, 02:03 AM   #5 (permalink)
mine is on my 3rd upfitter switch. works fine it operates my inline pump and electric valve.
2008 F-350 King Ranch 4X4, job build 3, tuned by Spartan
RIP: 95 F-350 Powerstroke, 4X4, 5 Spd, Crew Cab,Long Bed, 4" Superlift on 35" BFG All-Terrain, Diesel Innovations 4 Bank chip, 4" exhaust, DIY Tymar, Ranch Hand repalcement bumpers
2004.5 Cummins 600, 2500 Larimie, 4X4, LWB, 48RE, Full billet DTT, FASS fuel system, TST, SMARTY, Flux 3 injectors, Helix cam, Di-Procol (Boost, EGT, Trans, Rail, Fuel), AFE PG7 stage 1, JL Stealth box, Donaldson, 315 BFGs. (893 on fuel )
2005 Chevy 2500 Duramax, Diablo tuner, PYRO.
powerstrokin03 is offline
Old 10-28-2009, 01:23 PM   #6 (permalink)
Sounds pretty nice.. I figure what I never knew I will never miss. I thought about that option too. But then I figured I still have to set the timer .. and why wind that up and then throw a toggle (upfitter ) too. One more step in the process. I am sure I can bypass the timer switch but then I have one more thing to think about. This takes the guess work out of it. If I wind it up and it shuts off after pumping for 15 minutes and an extra 22.5 gallons, that is great. I have the ability to do this almost 3 times when full and miss the third full fill by 2.5 gallons.
The beauty of it for me is I can monitor the amount in the aux. tank. Again, for me it is a pretty good deal. At this point, I cannot see a disadvantage to it. Coming from nothing to this is a million % better.
Eclipse AVN726E Nav
Old 10-28-2009, 04:35 PM   #7 (permalink)
warweasel's Avatar
Thanks for the input! I guess I have a bit to learn about the auxiliary tank. My 08 didn't have it, and this one already has it installed. I'm pretty sure that I'll get it figured out eventually.
Old 10-28-2009, 04:49 PM   #8 (permalink)
Ive hooked up lights and a train horn to mine with no problem. just a little tricky to find the wires at first. something like a fuel pump i would put to switch one because of the higher amps.
inino is offline
Old 10-28-2009, 07:18 PM   #9 (permalink)
Sprinks542's Avatar
inino,could u give a little insight to where the wires are for the uplifter switches?
2008 F-350 Lariat PSD.
2010 Fuzion 322 TE II Toy Hauler
07 Can-Am 800 xt
08 Can-Am 500 Renegade
Sprinks542 is offline
Old 10-28-2009, 09:05 PM   #10 (permalink)
they are on the drivers side attached to some wires tucked up in the top. you have to take off the plastic piece to see around and stick your head kinda where your pedals are. they are kinda hard to spot with so many wires up there but you can find them.
https://www.fleet.ford.com/truckbbas...tml/Q117R1.pdf
inino is offline
Old 10-28-2009, 09:34 PM   #11 (permalink)
Sprinks542's Avatar
thanks man, really appreciate the help. I am also thinking of hooking up a compressor and horns to those also.
07 Can-Am 800 xt
Old 11-02-2009, 07:40 AM   #12 (permalink)
GoingBig's Avatar
I had the same problem until I added a very small buzzer from Radio Shack. On mine, I added a normally closed electric solenoid, a fuel filter, and a electric pump, all operated from the uplifter switch on the dash.
2008 Ford F350 FX4
6.4 Power Stroke Diesel Super Duty Crew Cab SRW 3.73 Axle, Tow Command - Bone Stock
GoingBig is offline
Old 11-03-2009, 08:13 AM   #13 (permalink)
jonrjen's Avatar
My larger truck is a full blown Regency Conversion F-550 Hauler. It came with a 90 gallon aux tank on the bed. The tank switch over is hooked up to the upfitter switch and works great. Kept the dash nice and clean.
2008 F-550 Regency Conversion Hauler 6.4 PSD
2006 Ford F-250 XL V-10 6-Speed
2006 Ford F-150 Crew Cab XLT
2005 Lincoln LS Sport
1977 F-600 Cab-Chassis V-8 4-Speed 2 Speed rear
1997 Travel Supreme 40' triple slide 5th wheel
38 +or- head of Texas Longhorn Cattle..."REAL COWS Have HORNS"
jonrjen is offline
