Auxillary tank under the bed for 2008 F350? - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 09-14-2007, 10:47 AM   #16 (permalink)
westvandude's Avatar
Re: Auxillary tank under the bed for 2008 F350?
You guys are correct.
The other thing which most people don't think about is how much your fuel economy suffers if you installed a 90gal tank in the bed. That's a lot of weight to be dragging around. Not so much an issue on the hwy but in city stop/go traffic it's a huge fuel hog to get that weight rolling at each light.
If it was water (diesel is lighter) 90gal would be 340L or about 750lbs. No chump change there.
In that regard, the manufacturer has to make some concessions as well. If the tank is too large EPA fuel economy goes down, they don't want that either.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
Old 09-14-2007, 01:33 PM   #17 (permalink)
RockRidge's Avatar
90 gallons of diesel would weigh 639 lbs (7.1 lbs/gal)
90 gallons of water would weigh 720 lbs. (8 lbs/gal)
Plus the weight of the tank and hoses, mounting hardware, etc.
'08 F350 FX4 Blue LB SRW 6.4L Auto 3.73 Sirius Tow Pkg (Born 3/20/2007 - Mine 4/13/2007--Friday the 13th!)
'01 28' Aljo Fifth Wheel (About 12K Loaded)
'07 Escape, Blue (Wifes) '03 Escape (sold)
'05 Escape, Green (Sons)
'03 F250 XLT Blue 6.0L Auto SB 3.73 & tow pkg (SOLD)
'90 Jeep Wrangler
RockRidge is offline
Old 09-15-2007, 01:18 AM   #18 (permalink)
FYI
90 gallons of water would weigh 749.7 lbs (8.33lbs/gal)
Robbie
p.s. Didnt mean to sound as much of a smartass as it did when I read it.
2008 F-250 Superduty Black Extended-cab Short-bed XLT
2006 F-150 King Ranch Dark Stone Crew-cab Short-bed
ff1809 is offline
Old 09-15-2007, 02:17 AM   #19 (permalink)
Yup. 90 x 3.78L = 340.2L = 340.2kg @ 20deg C x 2.2 = 748.44lbs. Depends which way you add it up I guess..... the water weight that is.
But who's counting.... any way you look at it... it's HEAVY! LOL
Old 09-15-2007, 10:41 AM   #20 (permalink)
FTG-05's Avatar
My Photos: (25)
All true, but misses the bigger point: There's nothing that says you have to keep it full when driving around town. I don't. I only drive with it full on long trips. It's nice being able to drive from North Alabama to Pittsburgh and back without having to buy fuel, if I choose not to.
It's all about choice. 30/35/38 gallon tanks don't give you as much choice.
+128 gallon capacity, does.
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 09-16-2007, 02:28 AM   #21 (permalink)
Yup.... you're right.
In fact, I was looking at the options on tanks last week. There were a few ads in the diesel magazines I bought.
Also great for filling up south of the border (cheap fuel), however, Canada customs has the right to ding you taxes on the fuel that's in your auxiliary tank (that's why you buy the one that looks like a tool box!) [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img] . If it's not factory-installed you can get taxed. Don't try filling up one of those red Tidy-Tanks and expect to get away with it. Food for thought.
Old 10-17-2007, 03:15 PM   #22 (permalink)
Anyone know if the lieometer recognises the extra fuel of does it only compute based on the 40 gal stock tent?
Stealth03TDI is offline
