Big brake kit for 08 F250/350 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 10-16-2008, 11:55 AM   #1 (permalink)
Question Big brake kit for 08 F250/350
Who has upgraded their brakes? With an 8,000lb kerbweight the stock 13.5" brakes are somewhat lacking. It seems this has always been a failing on Ford vehicles. The c.15" brakes on the F450 are far meatier but there are fitment issues so aftermarket seems to be the answer.
With the stock 20" rims, there is room for 16.5" brakes with a little to spare. I don't need that big but would like at least 15" but the one proviso is I do not want cross-drilled as with this much weight they have a greate liklihood of splitting. So, does anyone have any good recommendations for the SoCal area?
Carl Lassiter is offline
Old 10-17-2008, 10:07 PM   #2 (permalink)
bens duper duty's Avatar
This is a great subject and would love to know more if anyone knows something? We do need more suitable braking components for our trucks.
bens duper duty is offline
Old 10-18-2008, 10:32 AM   #3 (permalink)
Feedback Score: 3 reviews
Hawk pads will help
Cary
caryt is online now
Old 10-18-2008, 11:36 AM   #4 (permalink)
Originally Posted by caryt View Post
Hawk pads will help
Yeah thats a given, of course hawk pads will help.
BUT are there more options for our trucks?
I know if you change to rbf600 brake fluid, hawk pads and steel braided lines, it will help alot, but is there something better?
Old 10-20-2008, 11:45 AM   #5 (permalink)
So it seems we're at a dead end of sorts. My web research has led me to sites where the brakes are either even smaller than the stockers, available only on older SDs while a recommendation to look at another brake maker showed brakes with bizarre cross drilled pattern that look like they wouldn't last five minutes.
Caryt- Hawk pads recommendation is certainly a sound one, but would be nice to combine these with big rotors.
Are there any vendors out there who can help? Two very interested customers here.
Ben- nice stable and it sounds like your problem is similar to mine in that 13.5" brakes on an 8,000lb unloaded rig just aren't giving you much confidence. I also have an 08 M5 where stock 15" stoppers are employed to stop 3,900lbs. Now, like you, I'm not expecting an SD to stop like that but certainly want more than factory. Let me know if you find anything.
Old 10-20-2008, 01:34 PM   #6 (permalink)
Stymie's Avatar
one thing to remember, is its not the outer diameter of a brake that matters, it is the swept area of the pad.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 10-20-2008, 01:50 PM   #7 (permalink)
These are pricey like most big brake kits, but are pretty sweet. I'd like to get these one day.
TCE Performance Products - Producing Winning Results since 1993
dpbuckster is offline
Old 10-20-2008, 03:35 PM   #8 (permalink)
What a great first post. I'll look into these more closely. Thank you.
Old 10-20-2008, 03:45 PM   #9 (permalink)
CZDiesel's Avatar
WOW!!!!! Those Wilwoods look incredible! I wonder what the durability is like on a tow rig that actually see miles?e
2004 F-350 4x4 CC DRW
6.0l all stock
105k no problems, clean oasis
Snug-Top Shell
Bed Rug
ARB Front Bumper
Rough Country leveling kit
Rough Country Nitro Shocks
Power Slot Rotors
EBC "Green Stuff" pads
24' Haulmark Jobsite
2007 Arctic Cat 650H1
CZDiesel is offline
Old 10-20-2008, 04:21 PM   #10 (permalink)
Stymie's Avatar
Thats todd's brakes. he sells a ton of kits to the guys on the lightning board im on. I've heard nothing but good reviews, and these are from guys road racing 5,000lb trucks.
17x9 Pro Comp 7189
Stymie is offline
Old 10-20-2008, 07:17 PM   #11 (permalink)
thecougar's Avatar
Wow those are awesome. I wonder if they fit under the stock 20s...
2008 F-250 6.4l Lariat SuperCab Long Box 4x4
thecougar is offline
Old 10-20-2008, 08:15 PM   #12 (permalink)
Thanks for the compliment!
After reading the below post about the wilwood brake kit, im VERY disappointed. I just lifted my truck on 18" wheels and NOT 20" like I should have. Otherwise I seriously would have ordered the brake kit 10 seconds ago.
I just cant justify reselling my wheels and tires at a loss just to buy another set.
Old 10-23-2008, 12:28 AM   #13 (permalink)
Yes, 16" rotors will fit behind our 20s.
Ben- your 18s with lift sounds perfect for off roading. Just put some miles on the new tires and consider a brake change in 10k or so.
Going to call the shop tomorrow. Trying to work out if I should get just fronts or front and rears (assuming availability). Any opinions?
Old 11-03-2008, 12:40 AM   #14 (permalink)
Id say do just the fronts and feel it out. Both front and rear "might" be overkill.
Old 11-03-2008, 09:50 AM   #15 (permalink)
Here is a link to another forum where there is a detailed article on a nice brake upgrade to cryo brakes and hawk pads.
Power Slot Installation and Overview
2008 White F-250 King Ranch 4x4 --- COWBOY CADILLAC---
AFE Stage II CAI - ProGuard 7
4" Lift
35" Toyo's with 20" Chrome AR Rims
Rhino-Lined
10% Tint
8K HIDS
Recon Clear Tail-Lights, Clear 3rd Brake Light, Clear Side Mirrors
In-Dash Pioneer TV with Bluetooth
Trainhorn with 5 gallon air tank and onboard air
Clarion remote start/alarm
Spartan 310
Headstuds are coming soon!
JaredWaites is offline
