They should be twist locked in the back of the headlamp assembly. Make sure you DON'T touch the glass of the new ones. Oil from your skin can cause hotspots and early failure.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually Photos
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
