Daytime running light delete? - Diesel Forum - TheDieselStop.com
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
post #1 of 17 (permalink) Old 12-21-2008, 06:51 PM Thread Starter
desertwheeler's Avatar
How can i delete my DRL on my 08. I dont like how i cant shut them off when the trucks in gear. Plus if i do HID's i dont think they will like the lower wattage at all.
08 F250 CC SB 4x4 New baby.
03 F250 SC LB 4x4 sold
In SO-CAL?
Check out Southern California Powerstrokes.(SOCAPS).
desertwheeler is offline
post #2 of 17 (permalink) Old 12-22-2008, 02:57 PM
i want to know how to do this also
I already have the HID kit for the headlights and foglights but haven't been able to put them on because of the daytime running lights. Someone please help! It's killing me to drive with the dim factory headlights. I have the 2008 F350 lariat if it matters.
nick4833 is offline
post #3 of 17 (permalink) Old 12-22-2008, 08:55 PM
compman72's Avatar
My Photos: (9)
I think that the dealer can turn them off. It is in the programming of the "Smart Junction Box".
2008
F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
Break Pressure switch (cruise control failure) 99,300 miles 3-13-12
New BF Goodrich Rugged Trail T/A tires after 101,400 miles on the original
BF Goodrich Rugged Trail T/A tires 3-27-12
New Batteries after an original boiled over at 105,300 miles 5-13-12
Fuel Pump Replaced (frame rail) 131,534 miles 4-5-13
compman72 is offline
post #4 of 17 (permalink) Old 01-01-2009, 11:50 PM Thread Starter
any one know for sure?
In SO-CAL?
post #5 of 17 (permalink) Old 01-02-2009, 10:42 AM
i thought the DRL only comes on when you have your headlight switch to the auto position (furthest left) when it is in vertical position means all the lights are off. I am going to be putting HID's on as well
09 F350 SRW- H&S Mini Maxx with KEM 7 tune card, AFE 4" dpf/doc delete, AFE PG7 drop in soon to be S&B CAI, and some other exterior/interior work
06 F350 SRW- IDP Livewire tuned, studded, CAI, 4" DP to empty, Sinister EGR Delete, 6.4 Banjos & Blue spring, New: oem turbo, ficm, oil cooler etc...
02 2500HD- Hypertech programmed, true duals, AEM CAI
Frndinalowplace is offline
post #6 of 17 (permalink) Old 01-02-2009, 03:49 PM
screamineagle's Avatar
The DRL is a programmed feature. The dealer has to turn off or turn them on via the computer. I had mine done this past summer.
screamineagle is offline
post #7 of 17 (permalink) Old 01-02-2009, 09:50 PM Thread Starter
Cool ill check into it.
and no they come on when you put it in drive.
In SO-CAL?
post #8 of 17 (permalink) Old 01-03-2009, 01:22 AM
mine dont come on at all unless i have the light switch in the auto position.
here is the order on my dial: (from left to right)
auto - uses the sensor to turn on the lights
off
parking lamps
headlights
pull out for fog lights
post #9 of 17 (permalink) Old 01-07-2009, 05:35 AM
reveye's Avatar
My Photos: (13)
Is this something that is done in certain states?? I ask, because I have never seen a Super Duty with DRL. I have owned a lot of SD's, and this is the first I have heard of this. You won't see any SD's around my neck of the woods with DRL, and come to think of it, in my travels up and down the east coast in the last year, I don't think I have ever even seen one on the road with DRL. Just curious.
Rev
1997 F250 HD,4x4,7.3 PSD All original
reveye is offline
post #10 of 17 (permalink) Old 01-11-2009, 07:47 PM
I had three of them with DRLs, 99,'02, and '05. I installed the relays, etc. myself.
SuperCharged is offline
post #11 of 17 (permalink) Old 01-11-2009, 08:57 PM
Old_Truck's Avatar
off
parking lamps
headlights
Mine are the same as stated above
2015 F450 Lariat, White Platinum, Adobe, Auto, Loaded
B&W gooseneck turnover mount
Old_Truck is offline
post #12 of 17 (permalink) Old 01-14-2009, 09:38 PM
This is a feature that the dealer can toggle on and off in the programming of the smart junction box. I had mine turned on a few months back.
bsexton is offline
post #13 of 17 (permalink) Old 01-15-2009, 06:23 PM
Old_Truck's Avatar
Smart junction box programming options
Here is a list of Smart junction box programming options (done by the dealer).
post #14 of 17 (permalink) Old 01-18-2009, 02:44 PM
I have a canadian 2000x that I need to turn the drls off. Is that a dealer only programmer or can a code reader/scanner do the trick? I refuse to pay ford anything if not needed!
05 excursion limited4x4 6.0 bone stock 00 excursion xlt4x4 7.3 stock 87 f250 6.9 4 spd4x4 ATS turbo 83 MBZ 300D 5 cyl turbo diesel 310 k 82 MBZ 300 SD 5 cyl turbo diesel 251 k
boomerbust is offline
post #15 of 17 (permalink) Old 01-18-2009, 11:42 PM
Old_Truck's Avatar
As far as I know it can only be done by the dealer Maybe someone else on the forum can help.
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
