DPF Delete Without Programmer - Diesel Forum - TheDieselStop.com
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
post #1 of 12 (permalink) Old 12-20-2011, 12:15 PM Thread Starter
I may have royally messed up. I bought a DTF delete pipe from CL. Bolt on for my 2008 f350 6.4. It did not come with a programmer and was told I didnt need one. I had a muffler shop bolt it on. Guy I bought it from said just to unplug the sensors and roll up the wires. After they bolted it on and backed it out of the shop I went to pick it up and it wont start, turn the key and nothing happens. Having them bolt the original equip back on and plug the sensors back up... will it start after this or am I going to have to take it to a ford dealer ? Help ????
mcsd137 is offline
post #2 of 12 (permalink) Old 12-20-2011, 12:19 PM Thread Starter
I read alot of forums before I decided to have it done. Never read anything like this happening........
mcsd137 is offline
post #3 of 12 (permalink) Old 12-20-2011, 12:24 PM
I'm not suprised that it wouldnt start. It may not re-start even after you re-install the OEM parts as the sensors will be in a the "off" position which is probably a major issue. I wonder what would happen if you put the sensor mounts on the dpf replacement pipe. Would it fire then? Good luck and let us know how it works out for you.
NVBlueF350 is offline
post #4 of 12 (permalink) Old 12-20-2011, 12:43 PM
you have now messed with Ford's mod monkey
may the Man upstairs have mercy on you
frank faucheux is offline
post #5 of 12 (permalink) Old 12-20-2011, 01:13 PM
senix's Avatar
Put the orginal DPF and sensors back in.
Remove the battery cables for a few, reconnect and hope and pray.
Take DPF delete pipe and store it away till you do some research and know what it entails to remove the emissions stuff.
More than likely you will need a tow.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #6 of 12 (permalink) Old 12-20-2011, 08:07 PM
guardrail22's Avatar
UNBELEIVEABLE!!!!!!!!!!!!
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2013
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline
post #7 of 12 (permalink) Old 12-20-2011, 08:07 PM
Did the guy sell you a set of spark plugs too?
New Truck
Traded March 2013
Traded In Nov 07:
post #8 of 12 (permalink) Old 12-20-2011, 08:12 PM Thread Starter
ok, had the shop put back on the stock equipment, unhook the battery..... nothing. Talked with a diesel shop and the ford dealership.......and a towing company. The computer will have to be flashed by the Ford Dealership. What an exspensive lesson I have learned,,,,,,My Daddy always said I was one of those that had to learn things the hard and exspensive way. I think I will just deal with the 9mpg from here on out. Thanks for your help today.....
mcsd137 is offline
post #9 of 12 (permalink) Old 12-20-2011, 08:19 PM
senix's Avatar
yeah, best to get it back up and running and lets see what or how things go...then if you want to do something consider a dpf on tune..
It happens.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #10 of 12 (permalink) Old 12-20-2011, 11:22 PM
The guy obviously didn't do an accurate amount of research before pulling the trigger, but that's kind of harsh--yet I did LOL.
All kidding aside, emissions products on any emissions-equipped diesel truck shouldn't be messed with. You won't pass inspection and when it does break down, you won't have the manufacturer's backing.
2008
F250 PSD XLT Super Cab Long Bed (4x2)
2006 Nissan Titan, 6 inch Procomp lift (4x2)
2000 Nissan Frontier, Custom Motorsports 8 inch lift (4x2)
timid1 is offline
post #11 of 12 (permalink) Old 12-21-2011, 10:58 AM
Feedback Score: 3 reviews
Buy a DPF Delete capable tuner (H&S Performance) and clear the codes, then tune truck. You will be good to go.
DSTRBD is offline
post #12 of 12 (permalink) Old 12-22-2011, 09:01 PM
Jburcham04's Avatar
Lmao guardrail
My drinking team has a racing problem!!!!
08 F-350, diamond 5" turbo back exhaust (dpf/cat delete), AFE air filter (stock intake), back maxx, Nitto 325/60R20 (35's) terra grappler tires, 2.5 daystar leveling kit, bds shocks, icon adjustable trackbar, painted fender vents
Jburcham04 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
