Ford Alarm 2W7J-19A498-AA HELP!!!! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 11-01-2009, 09:19 AM   #1 (permalink)
Fanuc's Avatar
Cool Ford Alarm 2W7J-19A498-AA HELP!!!!
I need some help here, I have the Ford alarm 2W7J-19A498-AA the other day my TPS went of so I stopped to check the air in my tires. I reset the TPS and went to start my truck, but it wouldn’t turn over. It acted like it does when you get out of the truck for over a min and kills the ignition. So I hit the key fob to unlock the truck like always, but it still won’t turn over.
So I pushed the bypass button and the truck started no problem but, now the alarm doesn’t automatically set the ignition kill when I get out of the truck and when I do set the alarm the LED does not flash.
When I got the truck new, I did not get a manual on this alarm.
So my question is did I put it in a valet mode? And if so how do I put it back to the normal mode
I have tried disconnecting the batteries to reset it but that didn’t work
Fanuc is offline
Old 11-07-2009, 07:02 PM   #2 (permalink)
Hi Fanuc,
Similar thing happened to me. Had it towed into my dealer and 5 days later they finally had the replacement part. The "anti-theft" wouldn't recognize the chip in the Key. They said it was a faulty module in the instrument panel.
2009 F350, Job2, 6.4L Diesel, Crew Cab, Long Box, Dually
AFE Stage 2
Bakflip Folding Hard Tonneau
15K 5th Hitch
Line-X
RV-Dawg is offline
