headlight strobes? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 09-04-2009, 04:21 PM   #1 (permalink)
headlight strobes?
Anyone here put strobes in their headlights yet?
i went to a custom shop and they couldnt do it b.c of the huge headlight housing...
reconr1 is offline
Old 09-04-2009, 04:32 PM   #2 (permalink)
it has in internal casing(the reflectie part) and and outer black housing. Looking to see if anyone has any details on how they did it. thanks.
reconr1 is offline
Old 09-04-2009, 05:10 PM   #3 (permalink)
KD7CAO's Avatar
Stobes Installed and look great...
My F-250SD has strobes in Headlights, Front Marker/Turn, Reverse, and Tail/Brake Light.
I chose to go with a Flange Mounting design that would facilitate removal if it was ever needed. Install time was about 30 minutes for all the light assemblys including removal and re-installation. Can't tell they are there unless you look real close.
Eric KD7CAO
Basics:
2000 Ford F-250 SD Lariat, 4x4, 7.3L Diesel, Auto, 3.73 Rear End
Accessories:
Superchips 1705 Tuner, 5" Super Flow Exhaust, Dual Stage Garrett Turbo, Magnum Force Intake System, Headache Rack, Toolbox, Goose Neck Hitch, Yaesu FT-8900r Quad Band, Icom IC-2820h with D*STAR, Maxtrac and TT3+, Spectra 900, Whelen 90 Watt Strobe Pack for Rear - 4 Strobes (1 each) Brake Lights and Backup Lights, Whelen 75 Watt Strobe Pack for Front - 4 Strobes (1 each) Headlights and CL Lamps, Code3PSE Mastercom 3892L4, Sho-Me Arrow Controller and home built arrow stick.
Wants:
Front End Replacement bumper/grille, Locomotive Horn, Air Bags (suspension)
See Me: http://map.findu.com/kd7cao-2
KD7CAO is offline
Old 09-04-2009, 06:46 PM   #4 (permalink)
did you put them in yourself? b/c there is 2 housings i cant seem to figure out if there is a gromet to use or a whole lotta silicone?lol.
reconr1 is offline
Old 09-05-2009, 09:17 AM   #5 (permalink)
KD7CAO's Avatar
Strobes
Just drilled a hole using a step bit near the rear bottom of the light. I used a little silicon for water tightness but also made it removable for easy replacement. Actually the rear lights were harder do to the curved housings.
Sent from my iPhone.
Eric KD7CAO
Basics:
Accessories:
Wants:
KD7CAO is offline
Old 09-05-2009, 10:04 AM   #6 (permalink)
i wonder if the housing is the same. do you have an 08 or 2000?
b/c i cant do that with mine b/c their is an inner part and outer part...still confused...sorry.
reconr1 is offline
Old 09-27-2009, 08:02 AM   #7 (permalink)
sbrennan007's Avatar
The previous models were very easy to install. I think he is referring to his '00 model year. Those were super easy to install, not a 30 minute total job to complete all 4 corners, plus mount the power supply and run the wiring though.
The newer style looks to be a little different. I haven't looked at the rears yet on mine, but the fronts are sure a different design than previous years in regards to construction.
2011 F250 SC Lariat 6.7L Tuxedo Black
2011 BMW X5 XDrive Turbo
sbrennan007 is offline
Old 01-29-2010, 08:34 PM   #8 (permalink)
i installed mine myself, i just drilled holes in the headlight portion of the headlights just to the outside of each headlight bulb.
2008 f350 diesel cc lb 4x4 lariat, every option, 5% tint, leveling kit, harley 20s, hideaway strobes, western 7.5 pro plus
1999 f250 reg cab xlt 4x4 v10
sold- 06 F350 6.0 , auto, cc lb xlt, 4x4, sunroof, leveling kit, turbo back dual exhaust no mufler, sct livewire, accufab inlet elbow, Harley Davidson 20's w/ Nitto terra grapplers
<a href="link" target="_blank"> title </a> http://community.webshots.com/user/salnazzaro
salnazzaro is offline
Old 01-30-2010, 09:14 PM   #9 (permalink)
sorry I meat the top part the turn signal part
